Still a lack of boost, what else to do?
dub17
54
so i've been having a lack of boost for many weeks now, around 6/7psi when it should be more like 20, ive done the N249 bypass, replaced MAF, removed the pipe the goes from N75 to the actuaor just to test that, ive just removed the front bumper to look for loose or split hoses but everything seems to be in order (bumper is still curruntly off the car) just wondering what else i could try, i had two fault codes, one for MAF and one for N249 (16486 and 17695) i deleted the codes before i done the bypass and replaced MAF so maybe the codes came back, would that require me to delete them again if they did come back to maybe get it working again? what else could i do to try and sort this out? it's really getting to me! and help would be greatly apreciated, thankyou.
Pew.
1,436
138
Scotland
Deleting the codes wont automatically make whatever the code was for work again.
Do a scan and see if the codes are there first, if they aren't then there is obviously another problem.
Is it like a surging boost will it just not go passed 6/7 at all
dub17
54
i put the n75 hose straight back on, only removed one side of the hose to test it for a little run as thats how you test if its the n75 that is causing the problems, apparently. yeah the boost wont go past it at all. erm i cant say i've checked vac pipes, i dont really know where to look? just checked all the hoses that are to do with boost.
tstrahonja
541
Have u looked at your actuator threads? There should be 11-14 visible threads from top of actuator rod..
If u removed the hose that goes from n75 to actuator and still havent got boost then i think ure def have some actuator/wastegate problem.
Try pulling actuator with ur hand..it should be very very stiff.
dub17
54
there are 12 threads at the top of it. and it is not that easy to move it.
dub17
54
i think boost varies from like 3-8psi, but never more than 8. i could be wrong.
dub17
54
mapped to 190.
i got 9 codes just come up, erased them, took for a run, nothing, plugged it back in and one code remains (16795)
dub17
54
i have a boost gauge, check it for what? i know its not boosting to what it should be because i can feel the loss of power. or you saying that's where there might be a leak?
yes jay i have checked that pipework and it all seems to be okay there. im going to buy a few metres of hose tomorrow and get rid off all the factory fted stuff, what mm will i need? 6mm internal? (tubing for n75/n249 ect) the 6mm i used for n249 bypass seemed a tiny bit big.
dub17
54
i did the bypass to try and get it boosting normally but didn't make a difference, still only very very little boost.
6mm is to big 3mm standard or 4 I'd your running big psi.
Yeah ment the pipework to the boost gauge going though the car etc and easily get split.
My mate gauge its self broke up causing boost leak took him ages to find it as it was the last place anyone would think to check as it's so rare lol
