Recently i have had a few problems with the boost on my car as i am sure most of you are aware, now sometimes my traction control light comes on and stays on and i was told this is due to me over boosting getting the following code come up
16487 Mass Air Flow G70 signal too High
PO103-35-10 intermittant
Now when i clear this code the traction control light stays on, so i decided to investigate further i checked my ABS brakes for faults and i got the following code
01314 Engine Control Module 013 check DTC memory Intermittant
Now when i clear that code the traction control light goes off so what does that code meanand does it relate to my over boosting problem, the traction control light also goes off when i turn the ignition off and stays off even once i restart it.
Any ideas????????
Any ideas????????
