Stuttering & Loss of Power - Flashing Glow Plug
Fooxy
19
Hi Gents,
I was wondering if someone could help me solve an issue I have with my 58 plate PD170.
I was travelling to work and all of a sudden the car started stuttering and loss of power with the glow plug light flashing. I managed to get it back home and have it plugged in to see what was causing it.
Below is what I've received from the diagnostic - Does anyone know what could have caused this?
*I do apologise for the long post*
Friday,27,November,2015,20:07:33:09371
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: VSSZZZ1******** License Plate: YE58***
Mileage: 110070km-68394mi Repair Order:
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: VSSZZZ1PZ9R010558 Mileage: 110070km-68394miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 03G-906-018-BMN.clb
Part No SW: 03G 906 018 GQ HW: 03G 906 018 GQ
Component: R4 2.0l PPD1.2 G 2280
Revision: --H52--- Serial number: SEX7Z0H53140FV
Coding: 0050072
Shop #: WSC 66565 257 00032
VCID: 7AFC7BF935FBC2EE13-802E
5 Faults Found:
000802 - Engine Speed Sensor (G28)
P0322 - 006 - No Signal - Intermittent
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 39
Mileage: 110065 km
Time Indication: 0
Date: 2000.00.00
Time: 06:37:35
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 36.0 km/h
Bin. Bits: 00000001
Bin. Bits: 01000011
(no units): 11.0
Angle: 0.0 °
001602 - Sensor Reference Voltage A: Circuit
P0642 - 007 - Low - Intermittent
Freeze Frame:
Fault Status: 00000010
Fault Priority: 5
Fault Frequency: 2
Reset counter: 39
Mileage: 110065 km
Time Indication: 0
Date: 2000.00.00
Time: 06:37:35
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 27.0 km/h
Voltage: 4.61 V
Hex Value: 0x0002
Voltage: 14.35 V
Voltage: 14.46 V
005000 - Control Module Malfunction - DBW Throttle Monitoring
P1388 - 006 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 39
Mileage: 110067 km
Time Indication: 0
Date: 2000.00.00
Time: 06:41:16
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 27.0 km/h
35.88 %
Voltage: 1.76 V
Voltage: 1.62 V
Voltage: 14.35 V
000833 - Camshaft Position Sensor (G40)
P0341 - 006 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 39
Mileage: 110067 km
Time Indication: 0
Date: 2000.00.00
Time: 06:41:17
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 27.0 km/h
(no units): 5.0
Steering Angle: 0.00°
Angle: 0.0 °
(no units): 3.0
005686 - Powertrain Data Bus
P1636 - 009 - Missing Message from Airbag Controller - Intermittent
Freeze Frame:
Fault Status: 00000100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 39
Mileage: 110067 km
Time Indication: 0
Date: 2000.00.00
Time: 06:41:27
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 4.0 km/h
0.00 %
Voltage: 12.66 V
Bin. Bits: 11001111
Torque: 0.0 Nm
Readiness: N/A
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Coding: 163B6012092300FA681006E9902100823400
Shop #: WSC 04941 000 00000
VCID: 74E055C1D79FB49E49-8020
No fault code found.
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044 D
Component: ClimatronicPQ35 011 0702
Shop #: WSC 00000 000 00000
VCID: 2D5680A5B435A556C6-8078
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000005772432
Coding: 81880F2F00041000431D00000000000000007F075C400000000000000000
Shop #: WSC 06402 785 00200
VCID: 336296DD5211F3A690-8066
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 050608 022 0601
Coding: 00056208
Shop #: WSC 06402
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__A03 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPB74LHO
Coding: 0012339
VCID: 3B72BEFD7A413BE648-806E
Subsystem 1 - Serial number: 6333FTS630971298
Subsystem 2 - Serial number: 6343FTS661261298
Subsystem 3 - Serial number: 6353ETS614GFTVNH
Subsystem 4 - Serial number: 6363ETS6A74ITVNP
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BS HW: 1K0 953 549 BS
Component: J0527 752 0101
Coding: 0002042
VCID: 04000501473F841E79-8050
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 005 0060
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 947 C
Component: KOMBIINSTRUMENT VO3 0750
Coding: 0002401
Shop #: WSC 00581 067 57207
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533__Gateway H16 0202
Revision: H16 Serial number: 2700K08521113E
Coding: E9807F060006020203
VCID: 3566A8C55C65ED96BE-8060
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0750
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 L HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1518
Revision: 71009005 Serial number: 00000139488419
Coding: 0004784
VCID: 4088C91113A7583E1D-8014
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 142 2301
Revision: 00H15000
VCID: 2A5C8BB985DBB26E23-807E
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 988000005283CC7F0006850560085F86107C00
VCID: 0302061D4231832640-8056
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 06402
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 7 - Component: NGS n.mounted
1 Fault Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 2
Reset counter: 223
Time Indication: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 L HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1518
Revision: 71009005 Serial number: 00000529188418
Coding: 0004784
VCID: 418ECC1518AD513612-8014
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P2 035 186 A
Component: Radio BVX 0006
Coding: 0042424
VCID: 2B528EBD8A21AB66D8-807E
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1108
Revision: 11006001 Serial number: 00000003178793
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1108
Revision: 11006001 Serial number: 00000003155858
Coding: 0000144
VCID: 3C70BDE17F4F3CDE41-8068
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 5P0 862 335 B HW: 5P0 862 335 B
Component: FSE_2P5x H26 0110
Revision: 00000001 Serial number: 00000005030380
Coding: 0000555
VCID: 326C93D9AD0BFAAE9B-8066
End-------------------------(Elapsed Time: 02:09)--------------------------
mty12345
4,108
680
bristol
The fact that all the codes happened at the same time would make me think that maybe the power supply was interupted briefly. May be worth checking your battery cables are tight and that they are free from corrosion etc.
Fooxy
19
Hi, thanks for your reply.
I've checked the power supply and the cables seem fine from corrosion. The cables near the fuse box seemed really bad but I have cleaned them up and all fuses are fine.
It will not let me clear the engine malfunction errors from the car, seems really strange.
