Suction Jet Pump AUQ -Resolved
Sprogpole
360
Leicester
Hi,
So I have a leaky suction jet pump.
The only part listed for the AUQ engine is 06A133751AE. It is a full kit with check valves and pipes and costs around £70.
The BAM/AMK engine lists the pump as 058133753D. This is the pump only with no additional pipes and costs £25.
So, my question:
Is there are reason they only list the full kit for my AUQ, or can I use the pump from a BAM/AMK?
(Catch-Can is not an option for me)
Sprogpole
360
Leicester
You can also delete the suction pump, 1 vacuum leak less to worry about. Been driving around without one for about a year now.
Hows that work? just us a T peice instead?
Without the pump, there is no vacuum being pulled on the brakes when your manifold is under boost pressure.
Sprogpole
360
Leicester
I can confirm that the suction jet pump for the AUQ engine is the same part number as the BAM/AMK - 058133753D.
Odd that Seat does not list it on its own for the AUQ?
So, no need to by the full kit with all the pipes that’s about £70, even though all parts lists and the dealers will say you need to.
Unless you need the pipes, just get the £20 - 058133753D and some pipe clips and job done.
bo!
170
Advice needed .
Was on way home today car started to run extremely rough .so i pulled over and the suction jet pump had poped out of the plastic housing .pushed it back in and all was well but after a sprightly drive it poped out again .Q is will I just need a new suction jet pump or is this happening for another reason .
