stuart: cheers mate i had already printed ur
guide out and was using it, but figured out that the top or the strut has to be taken of with a 16mm (might have been 17mm) and an adjustable spanner holding the centre pin in place. The Koni FSD kit used an allen key instead of the spanner which was alot easier (dont forget to put the plastic cap or the nut will rust on the top of the shock. I forgot to put both on and had to take both shocks out again
). Was suprised how easy the rears were to change once i had done one.
You dont even need a set of spring compresors for the rears. Just get the car up on a jack or axle stands get someone to stand on the rear caliper which will push the suspension down enough to push the spring in. Found it a nightmare using compressors on the rears as there aint much room for the spring and the compressors bend it out of shape to make life harder.
Aint done the fronts yet cos couldnt get the shock out of the arm, but was looking online and there is a tool that goes onto a socket which u twist to free the shock so will invest in one and change them as soon as i can!!
Can notice a big difference with the handling even with just the rears on (hell of a weight difference in the new shock compared to the standard) and quality seems very good, was a little dissapointed with the ride height drop but will have to wait a few days for the Eibach springs to settle in (looks lower again this morning though). I know its only 25mm but mine needs it!!
Overall wish i could have fitted it all yesterday but gets dark so quick and been on the rally all weekend so couldnt face another cold night lol. Il let you all know how it feels with it all fitted
PS Sorry should relly have done a how 2
guide but just didnt have the time
