Tank flap Jammed but sometimes works.
hamst
93
16
Hi all,
Sometimes the tank flap stays locked doesnt open unless i do a lock/unlock.
Is this common? I read somewhere its a vag problem. Whats the best way to mitigate it? Do I have to replace the lock mechanism? If so whats the part number to buy and is it easy to do?
Thanks!!
rafletcher
531
215
Yes, it's common. The solenoid that operates the lock fails, and unfortuantely fails closed so the flap cannot bo opened without using force. It's a cheap enough part, around €30, and plenty of guides online on how to replace it if you fancy DIY.
For example
Reactions: Tell and hamst
Deleted member 98136
Yes as rafletcher said its a known problem, when mine started to play up, my local dealer done it under warranty, no questions asked ! Took them less than 20 minutes to replace the part(s).
However I must presume that yours is out of warranty now, otherwise you'd not be asking ?
Reactions: hamst
hamst
93
16
Yea its a 2019 model. Out of warranty. The vids I've seen are not exactly like the one i have. The ones in the video have a screw to access the mechanism but nine doesn't. You know the part number to replace?
Thanks!!
I'm sorry mate I don't, I presume its commom to Atecas and Leons
Its a shame you didn't take advantage of the "All in Seat" offer, which I did, it would have covered that.
I thought it was excellent value for money for what it cost.
hamst
93
16
For example
Thanks, would you by any chance know the part number? I check ebay and they're all around 25-30 euros
hamst
93
16
Its ok, I'm outside the UK, not sure this offer exists in europe anyways. Thanks for your help
Tell
Possibly this video since the Ateca is based on the Tiguan ?
I'll get the dealer to do it if it happens to me 😉. I don't believe in extended warranties but I did take out a 4 year service plan that was available from Seat online only but is no longer available. Child of inflation. Like an investment knowing their costs will increase. Did that before inflation kicked in.
I see the part number if specific to the original Ateca prior to 2020. Pass on whether they changed that for the FLs.
Loadmaster748
Roll on summer.....
Aug 2, 2019
315
130
Surrey, UK
A bit late to the party here, but I recently noticed that the tank flap tried to resist popping open when pushed - it always did but, was a bit of an effort.
All I did was spray some WD40 within the mechanism and it's worked fine ever since. However, I didn't realise before reading this thread that the solenoid issue was a known problem.
Reactions: Tell
