First off, just to be sure, is it an EA211 engine (turbo in front of or behind engine)? I have the 3 cylinder CHZB 95hp EA211 in my 2016
ibiza and these engines have roller cam followers - which I think is good - but they tend to rattle a bit when cold but get quieter when hot. So if the noise you are worrying about is that light tapping noise, then mine, with just coming up on 20,000 miles on the clock, actually sounds more noisy than that when cold. Worth considering too that all aluminium engines, as ours are, tend to sound more "tinny" than the older engines which had a lot of cast iron in them. The only other noise I'm hearing from your clip is the induction and exhaust noise when you are "goosing" it - sounds normal also? A better assessment of the follower noise could be made if you just slowly and gently increased the revs to, say, 2,000 rpm and then let it slowly decrease to idle again.
