tcs and abs light on help please!
damo-cupra
I parked my car up last night and was all okay. started it up this morning and the tcs and abs light stayed on so i turned engine off and tried agen and it stayed off. drove down road and it came back on any1 help me or no of any commen faults? Cheers
Chez
140
Edinburgh
Sounds like an ABS wheel sensor.
Maybe cleaning them up will solve it as they get lots of little metal filings stuck to them, (well mine do)
other than that you will need to replace the non working one.
BoostinHard
Flying @ 1.8 bar
Jun 6, 2012
12
Poole, Dorset
This happened to me whilst driving and i hadnt even touched the brakes.
I reset mine an is hadnt come back on, so as first post bits of rubbish could be interfering with the reading from an abs sensor, try cleaning all four then a reset
Good luck !
damo-cupra
Okay thanks. I have read that it could be the maf sensor but dont understand what thats got to do with tcs or abs bit comfused on that one lol
Apr 15, 2009
2,188
Midlands
Its worth checking the wiring to the abs sensors as incorrect fitting can cause the wheel to rub through the wires
TCS light normally comes on with maf fault but i havent seen it trigger abs lights before
ABS and TCS lights definately trigger with an abs fault, vagcom will give you the answer
shaun_m
this happened to me, make sure they wires aint rubbed and split
50spence
16
Bridgend
Check the fuses mate as mine was doing this and it turned out to be a 5 amp fuse under the dash. But I'm sure I was getting limp mode as well
