TDI's CompSport
CompSport
Hello,
We want to show you what we can do with 1,9 8V PD and 2,0 16V PD engines.
Here is the dyno charts.
Here is 2,0 TDI BKD engine with different turbocharger, 3" exchaust and bigger IC. The rest is Stock.
Here is 1,9 TDI ARL engine with different turbocharger, 2,5" exchaust, bigger IC and modified camshaft. The rest is Stock
These modifications are prepare for the street cars.
CompSport
It's completly different tuning firm and completly different car.
This Lupo is FWD. With 1,9 was Blue and now with 2,0 is Grey.
This car is pure diesel without lpg or something.
Aug 1, 2005
2,695
Cullompton . Devon
devonutopia said:
Think I've seen a clip of that Lupo on TDIclub. Black isn't it? I'm hoping mine will be around 240PS with the lpg running.
You noticed that Lupo as well then mate. It was running propane,NOS and a 2.1 stroker kit :drool: .
@ CompSport What turbo did you use to get those figures and at what boost?
CompSport
Turbocharger is our secret. I can tell that this is not na Hybrid. It's a Garrett VNT Charger called CS stage 2. We are runin on 1,85 bar.
CompSport
Tomorrow i show you some videos.
There is no smoke. Like I said these are a modifications for street use
redcupratdi
Offical SCN Pole Dancer
Oct 13, 2005
755
cambridge
Here is 1,9 TDI ARL engine with different turbocharger, 2,5" exchaust, bigger IC and modified camshaft. The rest is Stock (not much else to change.)
rest is stock what brakes and suspension?:help:
looks good how much is turbo?
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
Sounds like the modified cam helps a lot with the 1.9 in the second one. Its the only essential difference between my motor and this one. Mine's entirely still stock inside. Would love to know about race cams. :D There seems to be a mystery about them. I even have a spare pd150 cam that I'd happily use on exchange.
CompSport
I said that the rest of engine is stock of course.
Suspension Bilstein PSS, Front Brakes 280mm,Rear Brakes 239mm
body Kit Lupo GTI
redcupratdi
Oct 13, 2005
755
cambridge
body Kit Lupo GTI
only messing! sounds like a beast! well done.
just pound for power is bad on a deisel. (after a remap)
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
I'm a rubbish mechanic but I'm trying to get my head around the workings of a race cam. Are the lobes on it more pronounced than stock, so the process of injection / combustion is more pronounced, so it gives more power?
Was wondering also, where the power was measured - wheels or flywheel? Often wondered as it seems a hell of a battle when it comes to transmission losses and accurate readouts.
muddyboots
Still hanging around
Oct 16, 2002
5,739
In general, by altering the profile of the cam lobes, you can change:
1) The opening and closing times of the valves relative to the combustion cycle
2) The rate of opening/closing of the valves
and
3) The opening distance of the valves.
Not too familiar with cam tuning with respect to TDIs though....
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
Still impressed with the 2.0 TDI engine in the lupo. How is the engine management done? Is it stand alone, or did you manage to use all the electrics from the 2.0 TDI original car?
Good videos! :D
CompSport
In the begining it was 1,7 SDI. then we change the angine to 1,9PD and 6 Speed gearbox. We had to change the electrics and use the EDC15P ECU.
When we install 2,0 16V PD we had to modified the G28 Sensor (crankshaft positon sensor), G40 (camshaft position sensor) and we made it.
Our BKD is runin on EDC15P ECU, not like in a new cars on EDC16.
But the program is compleatly new only for this car, for example we are runin without air mass meter.
The fuel quantity is from the boost pressure.
Aug 1, 2005
2,695
Cullompton . Devon
QUOTE]
If you want some re profiled cams mate phone Allards as they have some in for the 1.9 PD , also got a nice ported head laying around.
