like?
i have had most things go wrong so spill mate lol
12 Faults Found:
000545 - Angle Sensor for Throttle (G188): Implausible Signal
P0221 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 2
Mileage: 9034 km
Time Indication: 0
Date: 2000.00.00
Time: 21:15:58
Freeze Frame:
RPM: 5384 /min
Load: 21.2 %
Speed: 77.0 km/h
Temperature: 84.0°C
Temperature: 34.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
005476 - Throttle Actuator (J338): Under-Voltage during Basic Setting
P1564 - 002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Mileage: 9072 km
Time Indication: 0
Date: 2000.00.00
Time: 22:31:43
Freeze Frame:
RPM: 0 /min
Load: 100.0 %
Speed: 0.0 km/h
Temperature: 97.0°C
Temperature: 55.0°C
Voltage: 10.668 V
000289 - Throttle Position Sensor (G69): Implausible Signal
P0121 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 9157 km
Time Indication: 0
Date: 2000.00.00
Time: 01:40:06
Freeze Frame:
RPM: 5046 /min
Load: 20.0 %
Speed: 65.0 km/h
Temperature: 90.0°C
Temperature: 27.0°C
Voltage: 14.224 V
001287 - Idle Control System RPM: Higher than Expected.
P0507 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 2
Mileage: 9159 km
Time Indication: 0
Date: 2000.00.00
Time: 01:42:10
Freeze Frame:
RPM: 1428 /min
Load: 17.2 %
Speed: 0.0 km/h
Temperature: 85.0°C
Temperature: 28.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 14.351 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 9304 km
Time Indication: 0
Date: 2000.00.00
Time: 00:01:42
Freeze Frame:
RPM: 6560 /min
Load: 29.0 %
Speed: 122.0 km/h
Temperature: 86.0°C
Temperature: 39.0°C
Voltage: 13.970 V
000771 - Cylinder 3: Misfire Detected
P0303 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 9304 km
Time Indication: 0
Date: 2000.00.00
Time: 00:01:42
Freeze Frame:
RPM: 6560 /min
Load: 29.0 %
Speed: 122.0 km/h
Temperature: 86.0°C
Temperature: 39.0°C
Voltage: 13.970 V
000770 - Cylinder 2: Misfire Detected
P0302 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 9304 km
Time Indication: 0
Date: 2000.00.00
Time: 00:01:42
Freeze Frame:
RPM: 6560 /min
Load: 29.0 %
Speed: 122.0 km/h
Temperature: 86.0°C
Temperature: 39.0°C
Voltage: 13.970 V
004688 - Fuel Level too Low
P1250 - 008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 9436 km
Time Indication: 0
Date: 2000.00.00
Time: 20:45:02
Freeze Frame:
RPM: 1435 /min
Load: 17.2 %
Speed: 0.0 km/h
Temperature: 85.0°C
Temperature: 28.0°C
Voltage: 14.351 V
000313 - Oxygen (Lambda) Sensor B1 S2: Response too Slow
P0139 - 004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 9467 km
Time Indication: 0
Date: 2000.00.00
Time: 18:37:03
Freeze Frame:
RPM: 2999 /min
Load: 9.0 %
Speed: 55.0 km/h
Temperature: 83.0°C
Temperature: 41.0°C
Voltage: 14.097 V
004372 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
P1114 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 9467 km
Time Indication: 0
Date: 2000.00.00
Time: 18:37:03
Freeze Frame:
RPM: 2964 /min
Load: 8.6 %
Speed: 55.0 km/h
Temperature: 83.0°C
Temperature: 42.0°C
Voltage: 14.097 V
005445 - Throttle Valve Controller: Malfunction
P1545 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Mileage: 9467 km
Time Indication: 0
Date: 2000.00.00
Time: 18:37:08
Freeze Frame:
RPM: 1386 /min
Load: 29.8 %
Speed: 38.0 km/h
Temperature: 83.0°C
Temperature: 45.0°C
Voltage: 14.097 V
P1545 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 9467 km
Time Indication: 0
Date: 2000.00.00
Time: 18:37:09
Freeze Frame:
RPM: 1145 /min
Load: 43.1 %
Speed: 36.0 km/h
Temperature: 83.0°C
Temperature: 45.0°C
Voltage: 14.097 V
2 Faults Found:
02214 - Tire Pressure Warning
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 63
Mileage: 8389 km
Time Indication: 0
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 397
Count: 50477
Count: 3
Count: 0
Count: 0
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 3
Reset counter: 82
Mileage: 9034 km
Time Indication: 0
Freeze Frame:
Count: 16448
Count: 32768
Count: 12800
Count: 8196
Count: 50475
Count: 1300
Count: 256
Count: 0
1 Fault Found:
01135 - Interior Monitoring Sensors
Freeze Frame:
Fault Priority: 4
Fault Frequency: 69
Reset counter: 82
Mileage: 743 km
Time Indication: 0
Date: 2000.00.00
Time: 23:23:43
blimey ! thats a few , well i would say probably coil packs for the missfires , same code i had with mine when it went.
the others look sensor related , engine cover loose and broken something?
wouldnt worry about the interior sensor i have that as well lol.
new thread?
Will create one after SEAT have had a look at it and see what they say.
Checked engine cover and not seen anything obvious or out of place. Its weird how one minute it runs really really rough, like the whole engine is shaking furiously and then the next it can work perfectly fine. Its well annoying though when it cut out and wouldnt restart, me and my mates pushing it back to mine and loads of people asking if I had run out of petrol, when In reality I pretty much had a full tank of v-power.
