morleymackam
190
Got this last night while pulling into a parking space. The engine had sounded a bit revvy when idiling but it didn't give me any other warnings before I switched it off. All seems ok now. Any idea what this could be?
HI could be the seat pressure pad on the passanger side somtimes play up :doh:
Things that ting..
1. Passenger seat if it detects weight
2. Drivers seat if your seatbelt was disconnected
3. Handbrake if it is applied while driving
4. Sidelights if you open the door with them on
5. Fuel low
6. Frost warning
7. CD player eject if theres no disc
8. Speed sensor warning if you go over the set limit
9. Tyre pressure resetting.
10. Possibly more that thankfully i've never heard..
Parking lights?
My passenger seat pressure pad plays up now and agin, briefly puts the light on and beeps loudly.
I think it defaults to the beep sequence so if it only senses it for a split second it will sound the beeps.
Unlikely to be your problem though.
Mine makes the noise if I open the door with the only the sidelights on but not if the headlights are on as well - is that a fault? I cant remember.
It won't be this, mine went off with a bag of shopping on the passenger seat last night - only beeped once then went off.
