Sneaky1337
67
When I drive I get a ticking noise pretty much every time. I got a check done because 2 of the doors don't work but I've ordered the part and getting them fixed this week.
Can anyone help with the other fault codes?
I've changed the battery in my key fob so that should of fixed that code.
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Friday,02,May,2014,17:10:36:62939
Chassis Type: 1P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: ** Mileage: 142680km/88657miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1P0 907 115 HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: 5BH16--- Serial number: SEZ7Z0G3761542
Coding: 0303000318070160
Shop #: WSC 04941 785 00200
VCID: E8DFDE2BDB86805EBC3-80BD
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004738
VCID: 73E539471240F386991-8026
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1P0 907 044
Component: ClimatronicPQ35 010 0502
Shop #: WSC 00000 000 00000
VCID: E9D9DB2FC08CB956A3D-80BC
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004869621
VCID: 6CD7223B4F7E2C7E58B
Subsystem 1 - Part No: 1P0 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 070507 022 0601
Coding: 00056208
Shop #: WSC 04941
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 L HW: 3C0 909 605 L
Component: R4 AIRBAG VW8 030 2522
Revision: 12030000 Serial number: 003B0P8TGCN+
Coding: 0021044
VCID: 2F6DF537BEE897663D9-807A
Subsystem 1 - Serial number: 6332MSME177A3261
Subsystem 2 - Serial number: 6342MSME182E4A09
Subsystem 3 - Serial number: 6351HTS6LNFK9O76
Subsystem 4 - Serial number: 6361HTS65JHKPM17
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 636 0070
Coding: 0002042
VCID: 8109E38FD8FC51161BD-80D4
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 005 0060
1 Fault Found:
00883 - Ignition Switch (D) Terminal S
012 - Electrical Fault in Circuit - Intermittent
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 925 B
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0002401
Shop #: WSC 54064 210 66681
VCID: 2E53E833B9E29E6E36F-807B
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 33001074130897
Coding: 3D3F034007000203
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0422
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 1T0 959 701 G HW: 1K0 959 793 M
Component: J386 TUER-SG FT 1130
Revision: 31008001 Serial number: 00000548578204
Coding: 0000688
VCID: 3B75D1677A907BC6811-806E
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.142 H07 1806
VCID: 3561C75F5CB4ADB6775-8060
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 998000005283CC7F0006050560085F86107C80
VCID: 8305E987C2E04306091-80D6
Subsystem 5 - Part No: 1P0 951 171
Component: Innenraumueberw.010 4971
Coding: 00000000
Shop #: WSC 04941
Subsystem 6 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 7 - Component: NGS n.mounted
2 Faults Found:
01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 91
Reset counter: 7
Time Indication: 0
00955 - Key 1
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 4
Fault Frequency: 7
Reset counter: 5
Time Indication: 0
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 1T0 959 702 G HW: 1K0 959 792 M
Component: J387 TUER-SG BT 1130
Revision: 31008001 Serial number: 00000082278226
Coding: 0000688
VCID: 3C77D27B7F9E7CFE88B-8069
2 Faults Found:
01553 - Motor for Central Locking; Passenger Door (V57); Lock
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 27
Mileage: 0 km
Time Indication: 0
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Reset counter: 242
Mileage: 139343 km
Time Indication: 0
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1P2 035 186 A
Component: Radio BVX 0006
Coding: 0040424
VCID: 2B55E1278AF0EB46111-807E
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 N HW: 1K0 959 795 H
Component: J388 TUER-SG HL 1108
Revision: 11006001 Serial number: 00000001537968
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 N HW: 1K0 959 794 H
Component: J389 TUER-SG HR 1108
Revision: 11006001 Serial number: 00000001541748
Coding: 0000144
1 Fault Found:
00931 - Locking Module for Central Locking; Rear Right (F223)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Reset counter: 243
Mileage: 137766 km
Time Indication: 0
End ---------------------------------------------------------------------
Can't help with most of it I'm afraid, but regarding the ticking noise, have you got the central locking set to auto lock, if so and there is an issue, it'll keep trying to lock everytime your speed drops below a certain level (15mph iirc) hence the clicking.
I think it's to do high my aircon I messed around with it and when is itch Econ on under off it stops for a while then comes back it's really strange.
