Tightening up a wing mirror
dm222
1,488
49
put pics.
likely it's damaged and nees replacement.
I broke one this week too :(
RUM4MO
8,084
1,108
South Scotland
Unfortunately it sounds like dm222 has given you the correct answer as currently he is very aware of how these things are put together!
everson38
470
35
walsall
Electric?
No manual. It moves a lot where the plastic meets the door
Sent from my SM-G900F using Tapatalk
a22tenc
145
That's easy to fix. Fold the mirror and you'll see the rubber film, there's a little hole in there use a torx key or a flat screwdriver and simply tighten the screw.
dm222
1,488
49
Try to tighten it as apsol said.
Manual are harder to remove, they need to remove the door card to remove.
