What I can make of all this goes as follows:
- Pre 11th June 2011 engine (codes up to 'CBZ 462 774 M' & 'CBZ 714 253 S') produced with the timing chain set 03F 198 158 which was the original set with the
problem chain that can elongate and result in engine failure.
- Post 11th June 2011/Pre 7th November 2011 engine (codes after 'CBZ 462 774 M' & 'CBZ 714 253 S') produced with timing chain set 03F 198 158 A which comprised of a reinforced chain and a new chain cover. The set was also made available as a repair kit for the pre June 2011 engines.
- Post November 2011 engine (codes unknown) produced with revised engine block (03F 103 101 B) had timing chain set 03F 198 158 B which comprised of a wider chain, new chain guides, new tensioner and an uprated upper sprocket.
The information that is not clear is at what stages the chain cover was implemented. From what I can gather:
- Pre 11th June 2011 engines had covers 03F 109 210 B
- Post 11th June 2011/Pre 7th November 2011 engines had covers 03F 109 210 C
- Post November 2011 engines had covers covers 03F 109 210 D
It could be that the post 11th June 2011/pre 7th November 2011 engines also had covers 03F 109 210 D introduced onto them later on but before the post 7th November 2011 engines (with timing set 03F 198 158 B ) due to having the addition of anti-slip teeth. However I'm guessing teh 03F 109 210 D cover is for the post November 2011 engines simply because there were so many changes to them, but there is no mention of a new cover in any of the information provided.
Could anyone with a post 7th November 2011 engine verify what the timing chain cover code is? Does anyone have a post 11th June 2011/pre 7th November 2011 with an 03F 109 210 D cover? The engine build date is written on the top right hand side of the engine number
sticker on the back of the intercooler and the timing cover code is written on the bump just above where the top section of the accessory belt runs.
