I don't know if VCDS will
help to locate a faulty power relay, but it might be worth posting in the VAG-Com forum to see if anyone in your area is willing to
help. The Altea/Toledo platform is Can-bus, so you'll need someone with full VCDS - the Lite version doesn't do Can-bus.
Might be worth asking in the Altea forums too, as you share their platform.
There are two panels with potentially relevant relays, in the dash area.
One relay panel with nine relay positions on it, you're interested in position 2, - Terminal 50 voltage supply relay -J682- (433) It should have the number 433 on its can.
1 - Not used
2 - Terminal 50 voltage supply relay -J682- (433)
3 - Not used
4 - Fuel pump relay -J17- (449) - Heated windscreen relay -J47- (404)
5 - Not used
6 - Not used
7 - Headlight washer system relay -J39- (53)
8 - Not used
9 - Not used
D - Window lifter single fuse - S37 (30A)
A second carrier is associated with the vehicle voltage control unit. The postions on this one appear to be labelled, from the diagrams. Positions B1, B4 and B9 might be relevant
B1 - Voltage supply relay -2-, terminal 15 - J681 (460)
B2 - Heated exterior mirror relay - J99 (449)
B3 - Not used
B4 - Voltage supply relay -2-, terminal 30 - J689 (449)
B5 - Heated rear window relay -J9- (53)
B6 - Dual tone horn relay - J4 (449)
B7 - Double washer pump relay -1- J729 (404)
B8 - Double washer pump relay -2- J730 (404)
B9 - X contact relief relay - J59 (460)
