t121anf
Newbie
May 14, 2004
573
9
Can anyone confirm the torque strings for a 2012 Leon when removing the struts?
I've looked at a number of guides for golfs but they vary depending on year.
Most specifically I need to know the axle/driveshaft bolt as its torque and then turn so many degrees.
Would prefer to know these also
Strut top nut
Strut locating bolts/nuts (3 at the top under the bonnet)
Sway bar
Lower control arm (3 of them)
The funny triple square one on the strut
Rears would be appreciated to.
Found this on tdiclub
Strut top 44
Strut locating bolts 11 + 90degrees
Funny triple square 52 +90 degrees
Stabiliser 48
Lower control arm 44
Axle 52 + 90degrees (52 with wheel off additional 90 when on the ground)
Rears
Upper 37 + 45degrees
Lower shock bolt 133
Lower control arm 66 +90 degree
Taken from
http://forums.tdiclub.com/showthread.php?t=273002
Anyone agree or disagree?
