petrol goes to the sump
diesel goes to the lower part of block
return pipes dont usually block its the feed pipe that blocks as it has a smaller diameter
I had a blocked return at it blew 2 turbos before i found out it was blocked . Loads of smoke is normally a result of a blockage as the oil returns bk to the turbo .
Will have to check that then cause was getting loads of smoke the other day after the car had say for about 4or 5 days drove about half a mile up the road cause the missus broke down in her car so had to go and jump start hers. And while I was doing it the smoke filled the whole street.
Yeah i would defo check it out because that sounds like your problem . I found wen going along it was ok " it must have been forcing past the blockage " but wen stationary its smoked really bad
