Major Tom
230
8
So if I turn off the ESC "permanently" with obd11, is it really permanently or is it just inverted function of how it is default? I mean, can I still turn ON ESC whenever I want to, using the button? Just that when I start the car it is in ESC off mode?
(Or ESP or TCS or whatever it is called :confused:)
If anyone else would ever wonder the same thing... It seems as if you cannot turn ESC off by default or permanently. ESC is always on at start, guess it's a safety thing, but the button can be programmed to be ESC Sport or ESC off different combos. At least I can now just make a fast push to turn ESC off and don't have to hold the button.
On an FR that doesn't have the button it would be interesting if someone can test if any adjustments can be done?
ESC is always programmed to be on the start, everytime you start your car, does not matter whether you disabled it previously, it is a safety function and will always be enabled unless you override this by switching it off.
