Nov 27, 2025
Hi All,
New poster here.
I currently drive a Seat Leon 21 plate. Earlier in the week, my missus drove over something which caused a roadside puncture. We got it to a nearby garage who replaced the tyre. Since then, then - the tyre pressure has dropped every single day (not by much so its not driveable) but I've had the Alert come up on the dash and had to put air it the tyre.
Now, I know square to nothing about cars - but if we've replaced the tyre - does anyone have any suggestions to what is causing the loss of Air?
Thanks,
Welcome, that doesn't sound ideal. I'd be taking it back to the garage as it sounds like a slow puncture which I'd be insiting was their issue to resolve and probably not right upon installation.
Hi All,
New poster here.
Thanks,
The answer is probably yes but I'll ask anyway:
Do you reset the tyre pressure monitoring system every time after inflating the tyre again ?
Reactions: Syphon
No worries - Yes, I do reset the monitoring system...
My worry is that isn't a tyre issue, its a Wheel/Rim issue? I just wondered if anyone else had a similar issue before I go back to the garage...
I would go back to them but i have in the past had a slow drain issue and took it to a tyre place, They resealed the tyre and problem went away.
But of course it could be a damaged wheel but I would expect the shop to tell you that when they are doing the balancing.
Yes if you dont reset it is likely to go off again. Also experienced a bit of sun on one side once which messed things up. That settled down. I was off to Ireland kept badgering me. Check, reset etc. Weird one.
Those garage / petrol pump gauges are suppose to be pretty inaccurate. Don't use them but cross check with a Halford gauge, branded, that memories front and back tyre pressures. Pump to above and let down to desired. That device beaps when you hit the range. So if you dont get them in the tolerance limit and reset etc etc. There will be more experts than me on how it sounds the alarm. A sticker in the door tells you the pressures normal. You dont pump to the soggy comfort figure.
This happened on my 2018 FR ST. Massive pot hole, puncture, replaced the tyre. The pressure alert came up within a couple of days so I put more air in and reset the sensor. Came up again after a couple of days so I checked the air and it was fine..... reset the alarm. It stayed off for ages so assumed it was just a dodgy sensor. When I next topped up all the tyres - reset the alarm and it turns on again after a couple days. Checked air.... fine. Rest alarm and it was ok for ages.
I guess what I'm saying is check the air as the sensor can get knocked on a pot hole and do funny things! I didn't bother replacing the sensor once I had figured out its nuances.
@yonny are you sure that your car's wheels do have tyre pressure sensors fitted in/on them, typically VW Group cars just use the ABS wheel road speed sensor info to work out if there is a tyre losing air.
Some sales territories do require wheels to be fitted with tyre pressure sensors and they are known as "direct" tyre pressure sensors.
You should see that on the display with the individual pressures shown. If not, indirect. I can see why people like the direct method, no fumbling with a tyre gauge.
I’m ‘old school’ and I check my tyre pressures when I do my other regular checks (under bonnet fluids) and it only takes a few minutes to do. The TPMS isn’t infallible and I’ve had false warnings - usually when we have a sudden cold weather spell.
Reactions: Tell
The fumbling is squatting down sticking the gauge on. The next bigger fumble is screwing in the pump. One of these Ring ones where you screw it in, the air escapes whilst you battle to get it on secure with no air leaks. Pump up over to allow a margin for escaping air. Then test with a proper gauge.
Yes I dont think you should use the warning in place of a physical check. It's not going to tell you if they have them all slowly deflating. Just when you have a puncture of one form or another sufficient to alarm you. The odd screw stuck in the tyre. Jet washing block paving throwing up those careless screws builders left on the drive or that tip run when they hadn't swept up the area. My punctures down to those of recent.
