tyre pressures
jay-bob 25
235
hi my leon fr tdi has this tyre pressure monitoring , if you adjust your tyre pressures do you have to reset this unit? has anyone had to do this yet.
Carnivor
244
In my LeonFR 2.0 TDI
yes, manually check and adjust your tyre pressures, then with ignition on press and hold the button until it boings at you, then your set.
i checked my tyre pressures when i got the car, found the rears were setup on the 4 passengers side of things,
mikejsing
I found my tyres were over inflated aswell - although when resetting the pressures i don;t get the 'boing' just a light flash up on the dash!
papdog
You need to hold it a bit longer and you will get the boing!
