tyre wear
Deleted member 19366
More than likely wheel alignment. But I'd get the camber checked aswell
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
The non R's dont have adjustable camber so it might be something you have to put up with?
Or you might be able to buy adjustable mounts to change the camber......or mabe the set up from a R?
drue1
193
kent
looks like it will be a wheel alignment on the cards but i want to get my 40mm lowering kit fitted fist and ive got a set of 18inch rims im powdercoating at work;);)
Lower it then put rims on and then get it aligned. Ask them to check the camber angle tho as this sounds like the problem. I know Adam said above there isnt camber adjustment on an lc, but it can be done.
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
I thought it was already lowered :redface:
As Dav3 said its best to wait until everything is done or you'll just end up having it done twice.
drue1
193
kent
:D:Dive had the kit sitting here for a few weeks.i was going to fit it but my strut brace was at work and i did not know what colour to podwer coat it but ive sorted my colour for my rims and strut brace;);)
