my fabia RS seems to have got upset at the cold weather...
In the past its had a problem (mainly when cold) with the turbo VNT blades sticking.. causing limp mode and charge pressure control: negative deviation (turbo not providing enough boost because the blades stay closed)
but today.. pretty cold morning, bout -4:
start car as normal.. wait 30 seconds or so then drive off gently.. as normal, engine is always a bit flat and rattly when its cold..
start to drive to work, up a slight incline... car starts to pull and then i felt it go into limp mode... i thought nothing of it, next set of traffic lights i stopped engine and restarted (normally clears it) but it didnt, and the engine check light came on.
so i plugged vagcom in when i got to work and got these codes:
17965 - charge pressure control - positive deviation
so the usual overboost fault code... nothing to be worried about!
18000 - Altitude sensor / Boost pressure sensor: implausable correlation
this one is whats getting me.. i cant clear it either. anyone know what it means/causes etc?
i had a look at the values reported in vagcom.. and the atmos and boost sensor show the same values.... so no problem there
i have a suspision it may be the MAF??? with the ignition on and the engine not running vagcom was showing 1250 for the maf? whats it suppost to be?
anyway any help/advice would be greatfully recived.. a 0-60 time of 40 seconds in limp mode is driving me nuts!
