Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
F2 Stu said:Not quite, the Antliock Bracking System is simply kicking in earlier as its not used to better discs & pads which have far more bite.
Or your being too over zealous as you have 'yay, Ive got new brakes'.......
Muttley said:The front and rear circuits are separate; ABS can be modulating the rears while still keeping full braking on the front. Each front wheel is separately modulated, too. You should find more braking is available if it is only the rears that are near to skidding - but you need a large empty space to check it out, certainly not on the open road. Big car park, after hours?
ibizacupra said:would'nt it show an ABS fault with a gap problem? intermittent sensor or something? as opposed coming in too early?
whats the symptums?
now thats damned interesting.cupra_matt said:Normally the ABS cuts in just before you stop, the problem being a slightly larger air gap on one sensor, so at low speeds the signal is very weak and the ECU thinks the wheel has locked hence the ABS cuts in,
This fault has never put a fault code in the memory that i have seen.
Another thing i have seen on certain models is a split sensor wheel causing an irregular signal.
Its worth checking and comparing the wave pattern from the sensors on an oscillascope, if poss.
