Vag 16955
adulka
116
Hi i have a problem :)
error in my car:
16955 Brake Light Switch (F): Implausible Signal
a replaced brake light switch, bulbs, every time i deleted a error in VAG but EPC Light still ON
brake lights shining correctly
:cry:
where can be mistake ?
Seatmann
Rough around the edges
Sep 16, 2010
5,575
10
Scotlanda
Have you just got one switch or two? Some of the seats have two like my cordy, you might be changing the wrong one.:)
adulka
116
hmmm i think, i have one switch, but it is not 100%
down is white switch and up is blue "switch"
here are image as they look like
blue (UP)
h t t p : / / img192.imageshack.us/img192/4121/31368831.jpg
white (DOWN)
h t t p : / / w w w .automatejcek.cz/picts/eshop/nahradni-dily/TCD201001/101/642761_0.jpg
this white i changed
this "blue" is too brake switch or something else?
it can also be bad?
Seatmann
Sep 16, 2010
5,575
10
Scotlanda
Your pics didn't work but they should now as you've cleared the 15 post mark but here's my switches and yeh it could be either of them.:)
adulka
116
yes they are
blue (UP)
white (DOWN)
i was changing this white (DOWN).
The blue switch is what?
Seatmann
Sep 16, 2010
5,575
10
Scotlanda
I think the bottom one does the brakes lights and the top one has something to do with the ecu, it tells the ecu that you've pressed the pedal, I've read some threads on other forums and it sounds complicated, they both have to match or it throws codes etc. Maybe either the blue switch is knackered or they're not adjusted correctly.:)
