joshyboy300b
23
hi guys does anyone have a link to a decent vagcom cable? have been on ebay and theres loads at all differnt prices :s
For good lead supplied by a UK VCDS dealer, I went to Gendan and bought their KKL lead.
VCDS Lite is a free download from the originator, Ross-Tech. The capabilities of the various versions are compared here. Registration of VCDS-Lite is $99.
Quite apart from the fact that the software supplied with these cheap eBay cables is in breach of Ross-Tech's rights, it has been hacked to make it work with a non-genuine cable. Now you may be happy to modify your car's ECU and control modules with dodgy software, but I'm not.
Are you saying that cable you have lee let's you use all the features of vcds with no problems?
Yeah it works fine for me, as I said before just make sure you switch off the internet before you run ghe software or connect the cable. Otherwise I think it tries to update and realises its pirated. Its not the most up to date software think its the 2008 version or something but is perfect for our cars.
Sounds good and would save me 200 odd notes. But would this work on the mk5 golfs?
Also what windows are you running?
And I will be able to do logs as well? Sounds to good to be true lol
I picked up one of these from best buy and was able to make changes to the locking/unlocking procedure from my remote but now can't seem to get it to work anymore.
I've uninstalled and reinstalled it several times but doesn't seem to register on VCDS plus in device manager it doesn't show as having picked up the drivers.
Sure I didn't have it connected to the net as I removed my USB wifi adapter before using (used the same usb port) but does this sound like what happens if it is connected to the net?
