VAG com help Stirling
Samalex
can anyone help off this week so any time would suit and hopefully the car will start :)
car lay for 8 days and when I jumped in to start the glow plug light never came on after loads of tries it eventually came on.
Had a few quirky things happen in last few weeks
Drop me an email or reply
Seatmann
Rough around the edges
Sep 16, 2010
5,575
10
Scotlanda
PD or non PD engine? Check in the fuse box for a relay with 109 printed on it, if you have it it's a very common one for failing and one of the main symptoms is no glow plug light. You could try pulling it out and giving it a tap on the ground a couple of times then plug it back in, it's not a total cure but it's got me going a couple of times now.:)
Failing that try this guy.
http://www.seatcupra.net/forums/showthread.php?t=313322
Samalex
I have a Leon Se Tdi (110) 2001 non pd engine I think
No relay in the fuse box looks like its under the dash will look in the morning thanks for the info
Seatmann
Sep 16, 2010
5,575
10
Scotlanda
Yeh it should be in the interior fuse box, it's the relay for the ecu etc so if the glowplug light doesn't come on the engine just cranks and cranks but wont start.:)
Samalex
sounds correct read some stuff on it and looks like it might be
just have to locate one tomorrow
cheers for the point in the relay direction
now just need to get the vag com done for peace of mind as well
Samalex
Think I need 15 post before i can pm I`ve been a lurker since I joined a year or so ago :)
Samalex
Seatmann cheers for the heads up on the relay
Just replaced it for cost 17quid old one had some dry joints 5 in total out of 11 connections so will repair that later and keep as a spare
now for help for VAG.com fingers crossed
I have a Leon Se Tdi (110) 2001 owned for 2years and driven by the wife before it was a mates who had it for about 4 years
