Seat_IbizaSC
45
So i got a VAG-com on saturday, didn't have enough time to look at it fully but i followed a tutorial to get staging working on seat ibiza 6j, when i come to the part to activate it, it says "Not Available" any ideas why? need proof of it working on a few on youtube and google.
What did you try and activate? I have it activated on my 14 plate FR. Under indicator celebration not under the staging option. I believe it only works with newer clocks but I may be wrong.
Are you using the right com port? Go in to device manage and check which port is being used, then make sure it is the same, then you should be able to get an active connection
Pretty sure it's working due to the fact i can do a error-scan and look at other things and be able to change so I'm sure I'm doing something right.
The staging option isn't avalaible on all Seat model that's all :/ (mine doesn't have it too )
Ah, Just seen that you need an 'advanced clocks' and as most of the videos show it working on the newer type of speedo, would putting the newer type work 'Plug and play' ?
