Warning Lights
Alex1888
62
21
Was driving home from work today and my 2015 Leon FR gave a jolt then the stability control light came on. It went off soon after but same thing happened again a few minutes later. About 5 minutes later the car gave another jolt and the stability light, tyre pressure light and park pilot lights came on. When I stopped at traffic lights I turned ignition off and back on and lights were gone.
Any help would be appreciated.
Thanks and sorry for long post.
Lozzy15
Mods mods mods
584
402
Ilkeston, Derbyshire
Ideally you'll want to read any codes left behind as to give you a hint to what happened, it should have logged an issue in one of the control modules. Usually these days a combo of dash lights are used to indicate an issue so it could be abit of a guessing game as to what the issue was without looking at the codes.
Alex1888
62
21
I took it to the garage but they called me today to say no codes are logged. I took a picture of my dashboard with the lights on and showed it to the mechanic. He's taking it out a run to replicate the error, hopefully so will wait and see when they call me back. Cheers.
Alex1888
62
21
Latest is that it's been in garage since Saturday but no fault has been found. They've took it a run for past 3 days and said it's running great and haven't replicated the fault so picking it up today. So will see how it is when I take it a run. Strange they can't find anything though. Fingers crossed it's ok.
Alex1888
62
21
Hi I know this is my old thread but really need help here guys. Still not had this issue solved. It's been in the garage 4 times now and is going back in tomorrow. The first 2 times the garage couldn't find anything, 3rd time they replaced crankshaft sensor, didn't help. 4th time they replaced camshaft sensor and wiring on the advice from Seat. Unfortunately it has now faulted again with same issues. Car shudders, loses power and stability control light, park pilot light, start/stop light and tyre pressure light all on. I switch car off and back on and it's fine. Any help or advice would be appreciated, thanks.
Alex1888
62
21
Car Scanner ELM OBD2
DTC report
Selected brand: Seat
============1==============
10763
Raw code: 002A0B
ECU: 02. Transmission control unit
Status: Test failed (current drive cycle)
Seat: P173400: Starter release from the selector lever sensor system
============2==============
17158
Raw code: 004306
ECU: 01. Engine control unit[Archive (inactive)]
Status: Test failed since last DTC clear
============3==============
4087
Raw code: 000FF7
Status: Test failed since last DTC clear, Test not completed during this operation cycle
Seat: P032200: Ign./Distributor Eng.Speed Inp.Circ.
No Signal
Status bits: 1
Priority: 2
Frequency: 1
Unlearning index: 255
Odometer: 128208 km
Date, time: 2022.09.12 14:52:41
============4==============
22532
Raw code: 005804
ECU: 04. Power steering[Archive (inactive)]
Status: Confirmed
Status bits: 1
Priority: 6
Frequency: 255
Unlearning index: 216
Odometer: 128208 km
============5==============
0522
Raw code: 00020A
ECU: 09. Onboard supply control unit[Archive (inactive)]
Status: Confirmed
Seat Alhambra 2011-2018: C115E54: Inertial sensors
No basic setting
Seat Toledo 2013 - 2018; Ibiza GP2 2016-2017; Ibiza 2017 - 2018; Ateca 2016-2018, Leon NF 2013 - 2018; 5F - A-CUV , 5F - Leon; Mii 2012-2018: B11FF15: Footwell lighting
Open circuit/short circuit to B
Seat Alhambra 2011-2018; 5F - A-CUV , 5F - Leon: B13A201: Speaker channel 3
Electrical error
Seat: B119B13: Power convertible top valve 1
Open circuit
Seat Ibiza GP2 2016-2017; Alhambra 2011-2018; Mii 2012-2018: B105F13: Left front bass speaker
Open circuit
Seat: Coolant Temperature Sensor-G62; Coolant temperature sender-G62
Status bits: 1
Priority: 6
Frequency: 12
Odometer: 128114 km
Date, time: 2022.09.08 18:46:57
============6==============
0531
Raw code: 000213
Status: Test failed, Confirmed
Seat Toledo 2013 - 2018; Ibiza GP2 2016-2017; Ibiza 2017 - 2018; Ateca 2016-2018, Leon NF 2013 - 2018; 5F - A-CUV , 5F - Leon; Mii 2012-2018: B11FF01: Footwell lighting
Electrical error
Seat Toledo 2013 - 2018; Ibiza GP2 2016-2017; Ibiza 2017 - 2018; Alhambra 2011-2018; Ateca 2016-2018, Leon NF 2013 - 2018; Mii 2012-2018: B110CF0: Connections to left rear speakers
Short circuit to each other
Seat: B128C11: Power convertible top valve 5
Short circuit to Ground (GND)
Seat: B1061F0: Left front treble speaker
Seat: B1385F0: Glow plug with flame monitoring
Ignition power too low
Seat: B1065F0: Left rear bass speaker
Seat: B1064F0: Right front treble speaker
Seat: Air mass reference voltage; Air mass meter reference voltage
Status bits: 1
Priority: 6
Frequency: 12
Unlearning index: 176
Odometer: 128114 km
Date, time: 2022.09.10 07:36:48
============7==============
203016
Raw code: 031908
Status: Confirmed
Seat: B140B29: Release button in rear lid handle
Implausible signal
Status bits: 1
Priority: 4
Frequency: 1
Odometer: 128209 km
Date, time: 2022.09.12 15:00:57
============8==============
262912
Raw code: 040300
Status: Confirmed
Seat: B1330F5: Anti-theft alarm system sensor
Alert - Emergency activation stage 1
Status bits: 1
Priority: 7
Frequency: 1
Unlearning index: 213
Odometer: 128114 km
============9==============
13637426
Raw code: D01732
ECU: 10. Parking Assistant 2[Archive (inactive)]
Status: Confirmed
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 128208 km
============10==============
617752
Raw code: 096D18
ECU: 16. Steering column[Archive (inactive)]
Status: Confirmed, Test not completed since last DTC clear
Status bits: 1
Priority: 2
Frequency: 2
Odometer: 128155 km
Date, time: 2022.09.10 20:35:47
============11==============
22532
Raw code: 005804
ECU: 44. Power steering[Archive (inactive)]
Status: Confirmed
Status bits: 1
Priority: 6
Frequency: 255
Odometer: 128208 km
============12==============
65588
Raw code: 010034
ECU: 52. Front passenger door electronics[Archive (inactive)]
Status: Confirmed
Seat Ateca 2016-2018, Leon NF 2013 - 2018: B148754: Motor for window regulator
No basic setting
Seat: B12D011: Left turn signal light bulb
Short circuit to ground
Seat: B126511: Heated rear window activation
Seat: B139F4B: Motor for convertible top operation
Excess temp.
Status bits: 1
Priority: 3
Frequency: 1
Odometer: 128114 km
Date, time: 2022.09.08 18:46:59
============13==============
13637426
Raw code: D01732
ECU: 76. Parking assistant[Archive (inactive)]
Status: Confirmed
Status bits: 1
Priority: 6
Frequency: 1
Odometer: 128208 km
Get Outlook for Android
Alex1888
62
21
Just to add I'm also getting the "error workshop leave vehicle in P position" error. Could this be related?
