Water in front and rear drivers side
May 5, 2023
Hi guys have been searching this page a lot but haven’t had any luck with sorting my leak out , I have water getting in behind the bonnet catch lever running Down and sitting in the corner , and also have water running in down the rear drivers side seat as if it’s coming from the boot , but for love or money I can’t work out where either are coming from , any suggestions except door seals sunroof drains or boot catch cable grommet
MoToJoJo
860
704
Northants
If you open the bonnet, under the plastics on the drivers side scuttle panel is a black plastic cover where the wiring harness goes to the fuse & relay panel under the dash. This has the same foam seal that degrades over time and let's water in
