I did the same on the bottom of the metal panel, although i found once i did that i had to take it all apart and seal round the bottom of the speaker aswell!!
id do all four speakers as i had to and get a vax or wet and dry hoover on it as i drained nearly four letres out of mine with one itll take ages for a demidfier
hi i had same prob , fixed the seals on the doors, but water stillllll got innnn. after weeks of looking i found that the water was getting innnn through the hard rubber seal that is on the side of the windscreen , and was getting in through the glass and the glass bonding. i could seeee the water dripppping on the bonnet realise handle. and there was a lot of it, i must have had 4 or 5 ltr of water out of the car using a de humidifier, the back footwell shoud be wetter than the front,,,, its the way the floor is built. hope this helps......
your seal under the door should leak that wear your drainage holes are if youve sealed them and your inner door your doors will fill with water there should be three holes in that seal if you rin your thinger inbetween
Yeah, that one downed on me and have now unsealed those drainage holes,,,,doh!
