what gearboxes will work with a 16v?
billye1980
hi ,, new to this forum ,, need some urgent info on gearboxs please
just bought ollie clarks old seat ibiza cup car reg {p983 ovv}
it has all parts except a gearbox ,,
i have to have the car ready for an event in 2 weeks time ,,
i have no experince with seat cars , but could yee tell me what gearboxs
will work with the 20 16v seat engine
either vw or seat , and which model and year to
,, all help greatly appreciated :confused::confused:
billye1980
gearbox
thanks for the info mate ,,
not to many mk3 golf gti gearboxs lying about the west of ireland though ,,
will the 020 or diesel gearbox fit ,,
dont really know anything bout these engines of gearboxs ,, just need one to make it
go ,, is the 02a a 6 speed box ?????????
thanks again :doh:
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
02A is 5 speed.
Any 02A box from mk2 golf 16v, corrdo, mk3 golf 16v, vr6.... but they all have different ratio codes!!!!
The one on the Ibiza 16v is CDA.... you can see this code stamped on the gearbox which is left of the selectors and down from the rubber inpection for the clutch.
This ratio/model code also lets you know how the output flanges fit to the diff..... found this out while trying to fit my peloquin diff.
billye1980
gearbox ,,
thanks for the quick replys guys
what other box in the seat range will fit that engine 2.0 16v :confused:
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
ASD Golf mk3 Diesel will physically fit but if you think the standard box has a long gearing in it then you'll be crazy to use it as it's hellishly long geared
:) i like it though
billye1980
gearbox
would it be ok for rallying ,,
is that the diesel gearbox from all mk 3 golfs ???
is it just a bolt in job ,,
or do i havee to change bits around ,,
thanks again for the info
will a 1.8/2.0 1994 passat petrol gearbox fit ?????????????????? :confused:
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
bolts straight in but for rallying ? lmao - forget it
it isnt any stronger to be honest just the ratios/diff are different and are way way too long for rallying sorry
i have a standard 16v CDA box here somewhere lying about but will need looking at
been apart and casing welded to patch up a hole and was changed as the sloppy gearchange was doing my head in and i could'nt be arsed to strip it again
big phill
big n proud
Feb 12, 2005
322
scunthorpe
what box did you use instead flapper
billye1980
but both the 020 and o2a will bolt straight in with no mods ya ???? :confused: :shrug:
Dave_R
Sep 20, 2004
3,666
South Wales
Nope...... 020 is rod change and 02A is cable change, if you fit a 020 you will need to change the flywheel, clutch and the method it uses to change gears.
billye1980
box
thanks again lads for the info 02a it has to be so .
any you guys know the price of a lsd for one of these :D
Dave_R
Sep 20, 2004
3,666
South Wales
Peloquin Diff is £670 with fitting kit...... make sure you give them that 3 letter code. I brought a new on from a member at club gti for £540 and turned out to be for a older 02A so I had to change the flanges that connect to the diff, the oil seal and remove the green cap on the box.
The diffs that you can get for the Ibiza is more a ATB diff than LSD
billye1980
box
one more :doh:
will a 1998 passat 1.8 turbo petrol box work ???
or a 1997 passat 1.8 petrol
will the seat inca van diesel box fit aswell ??????
thanks agin :worship:
billye1980
box
got a cda box ,, but its hydraulic ,, any mods to change it to cable to operate the clutch :confused:
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
ASD diesel gearbox currently - only any good for long cruising distances in all honesty as it's only just on tickover @ about 75mph but mines done all of 20 miles in 9 months so ill get back to ya soon with some actual gear speeds
unbolt the 2 bolts for the cyliinder and replace it with the right angle adapter thing the ibiza uses just dont forget the operating rod as well
straight bolt in swap on mine
so much so i stripped the hydraulic kit out a mk3 golf to see if i could make a conversion guide to go back to hydraulic as the box was originally
box end is easy as is pipe/fluid etc but pedal end still in progress as im still drilling :)
