Normal ET is 38 (mine were 37 btw ) if you go for ET 25 then the rim will sit out further which on the mk3 cupra is really not a bad thing as the wheels sit in quite a bit, especially the rear.
Note though, this is only for a non lowered car. Obviously the further the wheel falls outwards (meaning lower ET) the less you can lower the car say on coilovers. Else the wheel arch will sit on top of the wheel which is obviously not good for either the tyre or arch...
yeah but wudnt a 9inch wide wheel be naturally lower offset? so how could you get a wheel thats 9 inch with higher offset? its still going to be the same width the wheel ? or am i wrong?
I just explained, the higher the ET the more it goes inside the arch!!!
that means if you get a 9" wheel you get a LOWER!!!! ET value. Else you'll be hitting you're suspension and can't make turns without scrubbing all over!
With 9" wheels though you will be lucky if you can fit leaving enough room for the suspension/steering components without the wheels hanging past the arches.
You're both kind of right, but looking at the problem from different directions. As offset is measured to the middle of the width of the wheel (as is track), as the wheels get wider, you need to decrease the ET so the inside edge of the tyre clears the suspension and steering. The downside of this is that it means that the wheel will stick out of the arch that bit further - and a wheel that sticks out further than the bodywork will not generally be looked upon sympathetically by an MOT man. So you'd be getting into the realms of having the arches pulled of wheelarch extensions.
