Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Hey Guest💡👉 We have just launched our new Dealer Directory and review service Find out more now
Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps.
Did mine today the lugs were both knackered, but when I put my new pipe on it weren't as tight as I thought it would be but only time will tell I'll check it soon.
Sorry to dig this one up again. I have the same pipe blowing oil out of it. It had been fixed temporarily a few months back (I forgot about it! ) with a screw but its coming loose again now. Will I need to replace the hard plastic pipe that it connects into as well (is there a part number for this?)
The plastic pipe "should" be fine unless it's obviously damaged/warn. Replace the hose or just the end connector, you can get them cheap enough on eBay made out of billet aluminium that don't wear like the factory sort do. Also worth changing the C-clip as well while you're at it, a new more rigid and squarer edged one will help!
