kanyewest
519
144
NW
my mk4 6L ibiza burns through fuel quite fast, so im considering changing the spark plugs, but when i use the compatibility tool on ebay, it says none of them work with my car
its a 2008 ibiza sportrider. 1.4 petrol, 6L (unsure of BHP, but pretty sure its 16V). i dont know how to remove the plastic engine cover, but also need to know what plugs i need, i did check the manual but it doesnt say, honest
thanks!
Check what NGK suggest on their website, your engine type should be on the cam belt timing cover paper label - and else where.
The engine cover/air filter assembly just pulls off with maybe a small rubber pipe to remove once you can lift it up a bit.
It is secured by 4 large grommets being pushed down over 4 waisted pegs, start by rocking the front up and down at each end until you find one fixing point comes free then do the same with the other front one, after that do the same for the rears ones.
How much of the service are they actually doing though??
If they're just changing the plugs they could very well tell you to piss off.
theyre just changing the plugs and then checking my rear washer. fair enough about them telling me to piss off haha. its my first car so not sure about proper procedure for a lot of things
