What would cause these?
dirtydubber
As the title says, what would cause this combination of fault codes?
17608 - Recirculating valve for turbocharger - N249:mechanical malfunction.
16711 - P0327 Knock Sensor 1 Circ Low Input
16502 - P0118 Engine Coolant Temp.Circ High Input
16795 - P0411 Sec.Air Inj.Sys. Incorrect Flow Detected
17705 - P1297 Connection turbocharger - throttle valve pressure hose
First time all five codes were present, second time 17705 was not there, but it turned up again today, but 16502 was not present today.
dirtydubber
Yeah, I looked there, but it seems to suggest a different problem for each code mostly, and as all codes have shown up together at the same time, 3 times in a row, I am thinking that there is just one underlying cause. Just wondering if anyone has had the same or similarfault codes appear simultaneously, and what they found the cause to be. I dont have a huge amount of time available to tinker with the car looking at "maybes", due to the shift paterns I work
