w_inman
Can anybody please help.
My LCR has started running really bad.
Almost no boost, i fitted a new maf at the weekend thinking this would cure it.
Didnt seem to change anything so I invested in a vag com cable and have just got the following error codes...
VAG-COM Version: Release 409.1-S
Chassis Type: 1M - Seat Leon
Scan: 01,02,03,08,15,17,19,22,35,46,56
Address 01: Engine
Controller: 1ML 906 032
Component: 1.8l R4/5VT 0001
Coding: 10510
Shop #: WSC 00000
VSSZZZ1MZ3R056740 SEZ7Z0B1737262
5 Faults Found:
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-00 - -
16621 - Shareware Version. To Decode all DTCs
P0237 - 35-00 - Please Register/Activate
17796 - Shareware Version. To Decode all DTCs
P1388 - 35-10 - Please Register/Activate - Intermittent
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 35-00 - -
18010 - Shareware Version. To Decode all DTCs
P1602 - 35-10 - Please Register/Activate - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8N0 907 379 G
Component: ESP FRONT MK60 0101
Coding: 0019469
Shop #: WSC 00001
No fault code found.
I have bought a new Forge 007p so hopefully that should cure 17705
And after searching the forum 18010 just means the battery had been disconected?
Can someone please help with the other codes?
Address 01: Engine
Coding: 10510
Shop #: WSC 00000
5 Faults Found:
P1297 - 35-00 - -
P0106 - 35-00 - -
Coding: 0019469
Shop #: WSC 00001
