Wheel bearing change.garage job?
BigJase88
Jase
Apr 20, 2008
3,767
1,069
Front one is a garage job
If you want to save £ taking the hub off yourself is quite straight forward, and then take to a garage with a new bearing
Rear ones you can diy!
dazescort
44
isle of man
you can do back at home just need a puller to get hub with bearing of stub axle just take disc off and brake caliper of out of way should take about 1 hour if comes of ok. just make sure you take back part of bearing of stub axle can be pig to get off might need to grind off or cut a line in to free up or use puller .then clean up put back
