New Ibiza = Mk4?
Is so it's behind the drop down cubby hole next to the steering wheel. Not sure if it's the same on LHD cars though... :shrug:
yannis said:
Where exactly? Do you mean the little the little storage space that drops down? Do i have to take something out? Thank you!
Yup that's the one. It should come out if you push the clips down at the top and it should drop down.
I have just connected the KKL OBD II cable to the ibiza and i have a problem!! When running the Vag-Com program i get a FAST-SYNC: NO message. Is there a way round to the prob or am i using the wrong cable? I mean, is KKL OBD II compatible with my new ibiza? The com port status is ok and the interface status also ok in the test i run via Vag-com options.
