Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
car was serviced about 6-7 wks ago and I did get a new pollen filter. I ahve the exact same problem with build up in the sills but it then leaks into my car. It can get so bad that my carpet becomes marshy![]()
the build up of water on the sills is due to the door carrier seal deteriorating.
explained here for both the pollen filter and door carrier along with fix options:
http://seatcupra.net/forums/showthread.php?t=44216
i it was as wet as it sounds, LEE69 is correct the underlay / sound deadening material will the soaked through, its a bit of a pig job to get that dry as unless you cut it most of the interior needs to come out to remove it from the car.I think I've managed to soak that up, I've turned the sun newspaper for the last 5 days into a home made sponge and used it to absorb the water !
I have the build up on the sills and damp patches under my drivers mat after a rainy night, started reversing the car onto the drive so the rain doesnt hit that side,
really need to check all the usual places but never got round to it.
Let us know how you get on mate
