wide wheels on ibiza???
onephatcupra
hi there im going to run a set of porsche rims on my ibiza 20v with a width of 9.5 for the rear and 8.5 for the front
has anyone run or know wide wheels/split rims fit to ibiza??
pics would be cool! :)
dicko's
350bhp IHI Ibiza
Aug 5, 2008
240
Hartlepool
my compomotives are et15 which is quite far out and they also had 15mm spacers and tbh it use to catch like fook at the back and im on kw coilovers so had to remove the spacers to stop the catching. so i would say 9.5" will be a nightmare
Cupra Gsy
200
I have 8" on rear and fine and 8" on front with 10mm spacers lowered 100mm and i have no problems
GeorgeF
VW Tech
May 21, 2007
107
Essex
i have 8 all round with 20 and 30mm spacers, running low on weitec coilies. after some 9's for the rear though. think 9's should be fine, 9.5 should be alrite if you have enough stretch.
GeorgeF
VW Tech
May 21, 2007
107
Essex
GeorgeF
VW Tech
May 21, 2007
107
Essex
sorry i only have a few pics since i put the wheels on and none are very good. will sort some more out soon
johno1404
4 DOORS FOR MORE *****S
Aug 22, 2005
278
Hertfordshire
What size are yours George? Offset etc? Ive got a set of Porsche D90s in the back garden that came off a Porsche 944. Cant think of what size they are. I know the rears are wider than the fronts. Also where to i get hub adapters from and is that all i need?
Your car looks sweet on them D90s by the way.
GeorgeF
VW Tech
May 21, 2007
107
Essex
mine are 8J all round not sure on the offset off the top of my head. got my adapters from venom to. worked out to be one of the cheapest. very good service to.
alan_n
79
Uxbridge, West London
I've been offered a set of steel adaptors, opposed to the aluminium FK ones you boys have got, for £100 do you think i would be better of paying the extra bit and getting FK ones, as ive heard there better than cheaper steel ones?
Dec 13, 2006
724
Ashford, Middx
Got my adapters today, good service from venom. The adapters look good aswell.
My front wheels are et52.5 and the rears are et55. I bought 20mm adapters so it will bring the offsets down to 32.5 and 35. (7j fronts 8j rears)
GeorgeF
VW Tech
May 21, 2007
107
Essex
dont use steel adapters mate. sooo heavy. ur wheel bearings wont thank u for it nor will the handling fronts
