will this sub work with this amp?
digby130?
pocket rocket
Aug 10, 2008
305
exeter/london
sub specs:
•RMS Power Handling: 200W
•Peak Power: 800W
•Frequency Response: 30Hz - 400Hz
•Sensitivity: 91dB
•Impedance: 4 Ohms
•Cut-Out Diameter: 180mm (7-1/16")
•Mounting Depth: 112mm (4-3/8")
•Overall Diameter: 210mm (8-1/4")
amp specs:
JBL GT5-A604E Amplifier
•Amplifier Type Class AB
•RMS Power @ 4Ohms 4x60W
•RMS Power @ 2Ohms 4x80W
•Peak Power 640W
•Crossover (12dB/Oct., 20 – 320Hz; Front): LP/HP/Flat
•(12dB/Oct., 20 – 320Hz; Rear): LP/HP/Flat
•Signal-to-Noise (dBA) 85dBA
•Auxiliary Line-Level Outputs
•Bass Boost (+6dB @50Hz) Yes, variable
•Dimensions (H x W x D) 305 x 235 x 54mm
Mar 3, 2009
823
Hinckley
unless you are going to use 2 channels for the sub and the others for a front set of comps then the amp is a waste of money as youll only be half using it
