Wilwood
TimD
472
Anyone have any experience with the 280mm kit?
It comes with 4 Pot midi lites.
Also what lug size do i need, 76 or 94mm?
Tim
TimD
472
I've done a search, people where going with the 310mm kit.
Ideally, i'd like to make sure that a) the golf mk2 kits fit the ibiza and b) what size lug centres i'll need 76mm or 94mm :)
Tim
TimD
472
What was the price for the 310 kit?
I've been quoted 450 + vat for 280mm drilled and grooved discs. midlite calipers, carriers, etc.
Saul
<b>SCN Admin</b>
May 21, 2001
4,194
£600 odd i think, maybe slightly more
just make sure you check the clearances
Jay
86
france
Saul said:
twas i
http://www.seatcupra.net/knowledge_base/fitting_guides/wilwood_4_pot_brake_guide.html
must be the 94mm centres from memory, easiest way is take your wheel off and measure the bolt centres
i'm sorry if i ask you a "stupid" question but it's to be sure i've correctly understood what i've read (translated), in the guide you wrote :
The Brembos off the R had already peaked my interest, however i was unable to run my standard wheels, which i wanted to use for the track
does it mean the wilwood 4 caliper kit + 310mm disc can be used with the cupra's wheels ? :redface:
cu51pra
black ibiza cupra
Mar 15, 2005
1,111
harlow in essex
does it mean the wilwood 4 caliper kit + 310mm disc can be used with the cupra's wheels ? :redface:[/QUOTE]
with a 2mm spacer they fit ive tryed them:D
