Window closure Recode
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
at the moment for my windows to go up, i have to use the key in the door to close and lock the door. heard theres a way that enable me to lock/unlock and close/open the windows using my remote fob!
How do i actiavte it using vag.com? can tell step on how to do this
Chemical Al
Trollied Member
Apr 6, 2004
2,043
Craven Arms, Shropshire
not with vag com
yes with autowindow module for ££
yes with kvw 100 for ££
there is also a thread in the mk4 section that you could try will find it and edit in a sec
here
http://www.seatcupra.net/forums/showthread.php?t=93787&highlight=total+closure
from post 14
there is a lot of threads about the windows have a good search all methods are discussed (try searching other forums too, not just the leon)
Big_daddy
Oct 20, 2006
3,930
Brummy
so do i need a window module for mines? at the moment i could open and close the windows using the key in the door method!
Chemical Al
Trollied Member
Apr 6, 2004
2,043
with autowindows then yes you wire in a module
with kvw100 you plug a module into your obd2 port for 50 seconds then remove it
with the method described in the thread then no module and its free if it works
