doe
a problem with my car its a seat altea 5P from 2006 with a 2.0 TDI AUTO engine code BKD based on the vw golf mk5. Having problems with my electronics, here is a list of that are not working.
-wipers
-indicators
-climate control (not coming on at all)
-multi funtional steering controls
-the buttons for the onboard display
-radio wont go off even after key is out
-full beam and reverse light
-electric windows (drivers side will work sometimes)
-horn
-central locking (rear right door does lock all others dont and also no indicator lights when locking)
I have had it plugged into vagcom which showed me that its has no signal/communication from a couple control modules. The car starts and drives without any problems its only the electronics.
There's a thread on here from someone that experienced similar wobblers and it was a dodgy loom. Might be worth having a look for it.
Tuesday,01,December,2015,14:50:55:30340
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 15.7.2.0 (x64)
Data version: 20151124
Mileage: 146300km-90906mi
Chassis Type: 5P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: Mileage: 146300km-90906miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Cannot be reached 1100
09-Cent. Elect. -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Cannot be reached 1100
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: Cannot be reached 1100
56-Radio -- Status: Sporadic communication error 1000
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 HM HW: 028 101 227 8
Component: R4 2,0L EDC G000AG 7000
Revision: 12345678 Serial number: SEZ7Z033616784
Coding: 0050078
Shop #: WSC 06402 785 00200
VCID: 75E599381CB7B29648-8020
5 Faults Found:
18107 - Powertrain Data Bus
P1699 - 000 - Missing Message from Steering Wheel Electronics
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 1.0
18043 - Powertrain Data Bus
P1635 - 000 - Missing Message from A/C Controller
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 144.0
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 000 -
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.93 V
Temperature: 18.0°C
Temperature: 66.6°C
Temperature: 41.4°C
18080 - Coolant Fan Control 1
P1672 - 000 - Open or Short to Ground
Freeze Frame:
RPM: 0 /min
Torque: 26.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.39 V
Bin. Bits: 00001100
Temperature: 53.1°C
Duty Cycle: 9.6 %
17056 - Cylinder 2 Glow Plug Circuit (Q11)
P0672 - 000 - Electrical Fault
Freeze Frame:
RPM: 0 /min
Torque: 150.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.31 V
Bin. Bits: 00001100
Temperature: 7.2°C
Bin. Bits: 00110000
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 042 T HW: 02E 927 770 AE
Component: GSG DSG 070 1118
Revision: 04507000 Serial number: 00000601241464
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 2443947CE7AD7B1E2F-8070
3 Faults Found:
18275 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527)
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 255
Reset counter: 40
Mileage: 146297 km
Time Indication: 0
18250 - Please check DTC Memory of Instrument Cluster
P1842 - 000 -
Freeze Frame:
Fault Priority: 0
Reset counter: 1
Mileage: 146297 km
Time Indication: 0
16988 - Internal Control Module
P0604 - 000 - RAM Error - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Reset counter: 8
Time Indication: 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0006898
Shop #: WSC 04768 476 89568
VCID: 73E1A72012C3ACA666-8026
3 Faults Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
00778 - Steering Angle Sensor (G85)
014 - Defective
01314 - Engine Control Module
013 - Check DTC Memory
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 R HW: 1K0 909 605 R
Component: S9 AIRBAG VW8 018 2200
Revision: 02018000 Serial number: 0038MD07JMEM
Coding: 0021305
VCID: 3B714F007A1324E67E-806E
Subsystem 1 - Serial number: 6332MSME0E2F4C0DV
Subsystem 2 - Serial number: 6342MSME2904494FJ
Subsystem 3 - Serial number: 6351HSME09331F4BD
Subsystem 4 - Serial number: 6361HSME093C4E06G
3 Faults Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent - MIL ON
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
010 - Open or Short to Plus - Intermittent - MIL ON
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 5P0 920 923 A
Component: KOMBIINSTRUMENT VO3 0422
Coding: 0002401
VCID: 2F696B50BE6BC846C2-807A
3 Faults Found:
00457 - Control Module for Network (J519)
004 - No Signal/Communication
00779 - Outside Air Temp Sensor (G17)
01330 - Central Control Module for Central Convenience (J393)
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 280010611581C8
Coding: 3F3F0340078203
VCID: 2A5F7A448589AD6E15-807E
12 Faults Found:
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 6
Reset counter: 153
Mileage: 146286 km
Time Indication: 0
Date: 2000.00.00
Time: 00:02:13
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 153
Mileage: 146286 km
Time Indication: 0
Date: 2000.00.00
Time: 00:09:40
01332 - Door Control Module; Passenger Side (J387)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 153
Mileage: 146286 km
Time Indication: 0
Date: 2000.00.00
Time: 00:09:40
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 153
Mileage: 146286 km
Time Indication: 0
Date: 2000.00.00
Time: 00:09:40
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 153
Mileage: 146286 km
Time Indication: 0
Date: 2000.00.00
Time: 00:09:40
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 153
Mileage: 146286 km
Time Indication: 0
Date: 2000.00.00
Time: 00:09:40
Freeze Frame:
Fault Priority: 2
Fault Frequency: 40
Reset counter: 155
Mileage: 146286 km
Time Indication: 0
Date: 2000.00.00
Time: 00:09:44
Freeze Frame:
Fault Priority: 2
Fault Frequency: 40
Reset counter: 155
Mileage: 146286 km
Time Indication: 0
Date: 2000.00.00
Time: 00:09:44
01336 - Company Data Bus for Comfort System
Freeze Frame:
Fault Priority: 1
Fault Frequency: 38
Reset counter: 155
Mileage: 146286 km
Time Indication: 0
Date: 2000.00.00
Time: 00:22:33
Freeze Frame:
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 193
Mileage: 146287 km
Time Indication: 0
Date: 2000.00.00
Time: 03:33:01
01305 - Databus for Infotainment
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 195
Mileage: 146309 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:02
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 195
Mileage: 146309 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:05
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0422
Shop #: WSC 00000 000 00000
No fault code found.
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 3463643C574DEB9EBF-8060
1 Fault Found:
014 - Defective
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass.
Cannot be reached
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
End-------------------------(Elapsed Time: 01:44)--------------------------
