davidol
New ghetto whip :)
Aug 17, 2004
1,978
Cardiff
lol well not quite but hes sorted out the problem with my clutch pedal, turns out the rod that slides inside the clutch master cylinder actually clips into the white clip that goes inside the welded box on the side of the pedal, i didnt realise this whilst reassembling it (i didnt strip the pedal out, my uncle did it for me as i was working) and so thought it just rested in there from the pressure inside the master cylinder forcing it outwards
Jock also pointed out that it could only be clipped in with the pedal removed from its mountings and then it reassemabled with the rod clipped in to the clip.
My clutch is now silky smooth again and I can select all gears propperly, its been pissing me off for a while now so Im a happy bunny :D
On a more depressing note, my turbo back miltek exhaust arrived there this morning and Grant and Jock had the time to fit it but i didnt have the funds yet as it arrived earlier than expected lol, typically my luck!
Jock also took the car for a spin and agreed its not boosting as hard as it should be but i'd need to book it in for fault code reading as hes blown up his Vag-com :lol:
Anyways, happy days for now [B)]
well thanks for pointin it out daz you muppet! I asked everyone enough times including you so your off my christmas card list and on my 'special' list lol!
Aye, hes not bad. lol.
Glad its all sorted Dave, gottta get mine done soon, i'm working through the problems at the moment. Headlight adjuster is done, and the outside temp sensor is on order. Boot will be done this weekend, as will the dodgy connections on the gauges.
Sure when you want it? - I was joking about the discs ;)
Creaking dash
Rattleing seat,
Rattleing boot
Window doesnt close 1st time
Rattleing exhaust shield
Vag-com cable not working
Exhaust banging, when booting it out of a roundabout while on boost! (note:when momentum is pulling to the right. )
Fit oil pressure and temp gauges.
Anyone wanna swap problems? LOL
Rattly door
Rattly pod mount
Rattly exhaust on cold (supersprint will cure it)
Flush cooling system
Replace rear discs/pads
Fit samco intake
Fit top secret super special guage ;)
Fit other top secret super special gadget :D
Fit oil pressure guage
Mount dynatwist properly
Trim bumper around IC again
Lots and lots todo :)
Jonzy, i've gotta trim my bumper too, and sort out rattly pillar pod!
Im interested in the secret mods!
I'll mount your dynatwist for you, if you fit my oil guage!!
Pillar pod can be sorted with a bit of foam stuffed betwen the metal and fibreglass
Mount my dynatwist with what.... :lol: I havent made the bracket up yet!
Let me fit my pressure guage (work out how) and i'll do yours if ya like?
see told u it wasnt anythingserious ;) had to be a logical explanation somewhere, i would have thought to tell you to clip it onto the rod though :)
forbez re window problem: pull your battery off and reset the window close feature (in manual) :)
