Xenon headlight issue
Cammy_
39
Hi guys,
It's been a long while since I needed help but I have an issue I'm unsure about.
My drivers side dipped light has decided to stop working.
I've checked the bulbs by swapping them over and checked the fuses. I've also disconnected the battery to see if it resets it but still nothing.
Could it be my ballast is done? I did have dampness in the headlight but I've dried it out.
Any ideas how to either check the ballast or have I missed anything to try?
Cammy_
39
So I decided to go out and actually plug in VCDS to see what was going on.
It came back with this -
Address 55: Xenon Range Labels: 5M0-907-357-V2.lbl
Control Module Part Number: 5M0 907 357 C HW: 5M0 907 357 C
Component and/or Version: AFS-Steuergeraet 0148
Software Coding: 2557189
Work Shop Code: WSC 06402 785 00200
Additional Info: 7L6941329C AFS-Lst.-Modul l 0004 7L6941329C AFS-Lst.-Modul r 0004
VCID: 346D020957204E9
1 Fault Found:
00979 - Lamp for Low Beam; Right (M31)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 4
Fault Frequency: 1
Reset counter: 241
Mileage: 116048 km
Time Indication: 0
Date: 2126.14.27
Time: 08:55:04
Freeze Frame:
Voltage: 14.34 V
Speed: 0.0 km/h
ABS 1
Any ideas? as im still non the wiser!
Cammy_
39
So....
I took the ballast out today, when I removed it there was a lovely black mark on the circuit board. I decided to change the ballast over from the good side. Switched the ignition on and I heard a big crackle! Took it out and yup you guessed it its blown that one too!
So I took the headlight out, surprised how easy it was to get the bumper off! The cable from the ballast to the headlamp is burnt out.
I'm trying to source ballasts and the metal sheathed cable now. Fingers crossed that when I put the new ones in it doesn't blow them too!
I'll try post some pics!
Cammy_
39
Nope no headlights at all now! Luckily I'm off this week or I would up a creek without an ore!
