Just ordered a 3rd party VAGCOM, take a look
HasF
113
It seems to be on the page you linked to?
"This is new release Verison v12.12. 0"
Homer Simpson
229
22
I have similar, from different supplier. Cost was just under £12, works perfect on 12.12.0
On startup it prompts me there is an update, I just click no and continue
It does all I need it to do on a 10 year old car
/dev/null
1,649
101
Ok well I ordered one of these because I thought it was worth the risk for just over a tenner... The result? Works perfectly.
I have an Audi A3 Saloon (8v) model which is pretty new and I've just enabled needle sweep, lap timer and a couple of other things I found online.
Easy to install, works a treat. As with all non-genuine cables, just ensure you're not connected to the internet. It also sets your system date back when you run (part of the crack) so it could be worth setting it up in a little VM if you are going to use it a lot (or on a dedicated laptop).
For a tenner you really can't go wrong. £200+ for an original to do a few odd tweaks at home? No thanks.
leonlad
1,130
49
london
i bought one of these
was stone dead does nothing when you plug it in :(
Nicholai
Drive like you stole it:P
Mar 4, 2010
120
I have 2013 Ibiza ST 1.4.
I am pretty new to this vag com thing, and don't know which cable to choose, that it would work with my car.
This
http://www.aliexpress.com/item/Free...9-1-OBD2-OBD-OBDII-COM-Scanner/799537691.html
or this
http://www.aliexpress.com/item/Free...-12-12-VAG-11-11-6-VCDS-12-12/1698628668.html
What is the difference between VAG-COM and VCDS?
VCDS and VAG- Com are the same thing as a number of names. But the link at the top looks like a hacked cable which is risky as it has been known to course problems to your car. For piece of mind I wouldn't mess around I would buy the ross-tech genuine lead for piece of mind.
Baggik
Global Terminator
Oct 24, 2013
59
Slovenia
I know the cable is not genuine ross tech, but as i only need it for a one time job, i am not willing to pay 300€+ for a genuine cable.
So both of this cables should work?
Sent from outer space using tapatalk
