Facelift Xenon Retrofit
markmeus
Mark Graham
Jun 9, 2007
2,948
11
Banbridge, Northern Ireland
For anyone who has retrofitted the facelift Xenons with the DRL bulbs, do your DRLs work? I have the following errors.
Code:
Address 09: Cent. Elect.       Labels: 1K0-937-08x-09.clb
Control Module Part Number: 5K0 937 087 AC    HW: 5K0 937 087 AC
  Component and/or Version: BCM PQ35 H+   122 0174
           Software Coding: 46180A3EC825B0C042C80080950089CC44FD0008627D8560C88040000040
            Work Shop Code: WSC 12345 123 12345
                      VCID: 76E9D05DC1070991457-8023
2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 141
                    Mileage: 49303 km
                    Time Indication: 0
                    Date: 2033.14.26
                    Time: 12:59:28
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.40 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
02746 - Bulb for Daytime Running Light; Right
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 141
                    Mileage: 49303 km
                    Time Indication: 0
                    Date: 2033.14.26
                    Time: 12:59:28
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.40 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
If anyone with facelift Xenons, either factory or retrofitted could share their long coding it'd be greatly appreciated.
Speed-FReek
1,108
17
South Oxfordshire, UK
I've got factory fitted Bi-xenons and rear LED lights. This is the original "09-Central Electronics" long coding on mine before any tweaks were made (i.e. the original long coding value as programmed by SEAT at the factory)...
Code:
46180A3E8025B0C042080080950089C442550008727D8560008040000040
As you can see there a some bytes in mine that are different to yours.
