Would it not be enough to just use the SPS and run stock mode?
What is the difference between stock mode and removing the Revo file completely?
How about a crazy idea...Use the APR Trial Map and see the difference =
![Cool    [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
Guest, New Stock alert: Premium CUPRA valve caps now available in the store ? Order now from the merchandise store
How about a crazy idea...Use the APR Trial Map and see the difference =![Cool    [B)] [B)]](/forums/styles/seatcupra/oldforumsmileys/shades.gif)
Looking at my logs we can see that the EGT protection mode kicks in about 2500 RPM, that is when the ECU will push in more fuel to lower temps avoiding damage to the turbo. I have been notified that the ECU should not start to do this before 900C, on my logs about 2500 rpm i am only on about 800C .
Am i logging wrong group for EGT?
Can other factors activate the EGT protection mode as timing pull?
Yeah it would remove it. Have you had the car from new? Someone else on here was having weird things happen to his and it turned out to be a dodgy repository on the cylinder head as memory serves. When I get time away from travelling I will try to look for the details.
2500rpm and EGTSs are at 800c????? Thats not right at all, id expect engine to be under heavy load from 4500rpm and above, after having run through one or two gears atleast.
The EGT protection is there to stop things melting.
Id revert back to a bone stock OEM map and do testing from there, back to basics. revo stock mode isnt stock
	Group A:	002				Group B:	230				Group C:	231
		Engine Speed	Engine Load	Injection	Intake Air Mass		Rail Pressure	Rail Pressure	Rail Pressure			Pressure	Pressure	Load
	TIME			Timing		TIME	(specified)	(actual)	Difference		TIME
Marker	STAMP	/min	%	ms	g/s	STAMP	bar	bar	bar		STAMP	bar	bar	%
	0.14	1560	14.3	0.51	4.94	0.27	50	49.98	0.02		0.01	4	3.88	37.6
	0.52	1680	60.9	2.55	32.81	0.66	72.95	74.84	-1.89		0.39	4	3.94	39.6
	0.91	1640	75.2	2.81	28.94	1.03	95.77	98.25	-2.48		0.78	4	3.88	47.1
	1.3	1720	82	3.06	32.69	1.43	103.54	106.92	-3.38		1.18	4	4.19	46.7
	1.69	1800	89.5	3.31	37.39	1.82	105.85	108.29	-2.44		1.55	4	4.39	45.1
	2.07	1880	95.5	3.57	41.22	2.21	107.83	108.88	-1.05		1.94	4	4.41	44.7
	2.45	2000	102.3	3.57	46.47	2.58	109.83	110.41	-0.59		2.33	4	4.37	44.3
	2.85	2120	109.8	3.83	52.67	2.97	113.79	113.83	-0.05		2.72	4	4.29	44.3
	3.24	2240	118	4.08	61.11	3.36	118.32	118.87	-0.55		3.1	4	4.19	45.5
	3.61	2360	128.6	4.34	71.42	3.75	123.77	123.74	0.02		3.48	4	4.12	46.3
	4	2480	142.9	4.84	83.06	4.13	128.49	125.96	2.53		3.88	4	4.05	48.2
	4.39	2640	162.4	5.87	99.81	4.52	129.81	125.98	3.83		4.27	4	4	50.6
	4.78	2880	187.2	7.4	128.42	4.91	129.86	126.79	3.06		4.64	4	3.9	54.9
	5.16	3000	191.7	8.42	146.31	5.3	129.86	127.04	2.82		5.03	4	3.77	62
	5.55	3160	191.7	8.67	167.39	5.68	129.86	127.85	2.01		5.42	4	3.81	63.5
	5.94	3360	191.7	8.42	127.17	6.07	129.86	127.33	2.53		5.82	4	3.87	63.9
	6.33	3520	191.7	7.91	111.61	6.46	129.86	127.74	2.11		6.19	4	3.86	64.3
	6.7	3680	191.7	7.91	192.11	6.85	129.86	128.76	1.09		6.58	4	3.83	65.1
	7.09	3880	191.7	7.65	175.67	7.22	129.86	127.62	2.23		6.97	4	3.77	66.3
	7.49	4040	191.7	7.65	134.33	7.61	129.86	128.26	1.6		7.36	4	3.69	67.1
	7.88	4240	191.7	7.65	189.14	8	129.86	127.91	1.94		7.74	4	3.66	68.6
	8.25	4400	191.7	7.91	188.5	8.39	129.86	126.63	3.22		8.12	4	3.63	70.2
	8.64	4600	191.7	7.65	197.97	8.77	129.86	128.23	1.62		8.52	4	3.53	73.7
	9.03	4720	191.7	7.4	200.08	9.16	129.86	129.72	0.13		8.91	4	3.55	76.1
	9.43	4920	191.7	7.4	207	9.55	129.86	129.63	0.22		9.29	4	3.69	75.7
	9.8	5080	191.7	7.4	210.33	9.94	129.86	129.35	0.51		9.67	4	3.77	76.5
	10.19	5240	191.7	7.14	219.22	10.31	129.86	130.64	-0.78		10.07	4	3.76	78
	10.58	5400	191.7	7.14	223.69	10.71	129.86	128.98	0.87		10.46	4	3.71	81.6
	10.97	5560	191.7	7.14	230	11.1	129.86	129.2	0.66		10.83	4	3.76	84.3
	11.34	5680	191.7	7.4	238.22	11.49	129.86	129.22	0.63		11.22	4	3.95	78
	11.73	5840	191.7	7.4	245.08	11.86	129.86	129.26	0.6		11.61	4	3.74	88.6
	12.13	6000	191.7	7.14	242.72	12.25	129.86	132.76	-2.91		12	4	3.83	90.2
	12.52	6120	191.7	7.14	245.64	12.64	129.96	129.84	0.12		12.38	4	3.99	85.1
	12.89	6240	191.7	7.14	253.75	13.04	129.99	130.85	-0.87		12.77	4	3.96	85.9
	13.29	6360	191.7	7.4	251.78	13.41	129.99	130.68	-0.69		13.16	4	3.87	91.8020				115	230
Cylinder 1 Ignition	Cylinder 2 Ignition	Cylinder 3 Ignition	Cylinder 4 Ignition	Engine Speed	Rail Pressure	Rail Pressure	Rail Pressure
Angle Delay	Angle Delay	Angle Delay	Angle Delay		(specified)	(actual)	Difference
°KW	°KW	°KW	°KW	/min	bar	bar	bar
0	0	0	0	1760	52.19	52.31	-0.12
0	0	0	0	1800	72.66	74.03	-1.37
0	0	0	0	1840	98.06	100.48	-2.42
0	0	0	0	1920	107.37	109.71	-2.35
0	0	0	0	2000	110.66	112.44	-1.78
-3	0	0	-3	2120	114.71	116.19	-1.49
-3	-3	-3	-4.5	2240	119.43	120.98	-1.56
-3	-3	-3	-4.5	2360	125.05	126.03	-0.99
-6	-3	-3	-4.5	2520	129.13	126.26	2.86
-6	-6	-3	-4.5	2680	129.13	125.23	3.9
-6	-6	-3	-4.5	2880	129.13	127.45	1.67
-6	-6	-3	-4.5	3080	129.13	126.31	2.81
-6	-6	-3	-3.8	3280	129.13	126.6	2.53
-6	-6	-2.3	-3.8	3440	129.13	128.19	0.94
-5.3	-6	-2.3	-3.8	3600	129.13	127.01	2.11
-5.3	-5.3	-1.5	-3	3760	129.13	129.08	0.04
-4.5	-4.5	-0.8	-2.3	3920	129.13	129.08	0.04
-6.8	-4.5	-0.8	-2.3	4080	129.13	128.76	0.36
-6.8	-3.8	0	-1.5	4280	129.13	128.38	0.74
-6.8	-3.8	0	-1.5	4440	129.13	128.72	0.41
-5.3	-3	0	-0.8	4640	129.13	128.2	0.92
-5.3	-3	0	-0.8	4760	129.13	130.17	-1.04
-4.5	-2.3	0	0	4960	129.13	127.2	1.93
-4.5	-2.3	0	0	5080	129.13	130.49	-1.36
-3.8	-1.5	0	0	5240	129.13	128.1	1.03
-3.8	-1.5	0	0	5400	129.13	129.33	-0.21
-3.8	-0.8	0	0	5560	129.13	129.4	-0.28
-3	-0.8	0	0	5680	129.13	129.15	-0.02
-3	-0.8	0	0	5840	129.13	130.35	-1.23
-2.3	0	0	0	6000	129.13	131.46	-2.34
-2.3	0	0	0	6120	129.13	126.54	2.58
-2.3	0	0	0	6240	129.13	129.5	-0.38
-1.5	0	0	0	6360	129.13	130.11	-0.99I think this might be what my car is suffering from ? What engine codes do you get?!
Running lean on idle?
Yes should be 4 bar from memoryHad a chat with Sorensen Performance in Denamrk about the issue i have with my car and got a suggestion that this is due to the LPFP .
Well after logging block 231 it seems obvious that LPFP or fuel filter are messed up.
See my logs below. Can anyone confirm what the difference between specified and actual LPFP value should be.
I think Sorensen Performance indicated actual value should at least be 4 bar at full throttle.
Code:Group A: 002 Group B: 230 Group C: 231 Engine Speed Engine Load Injection Intake Air Mass Rail Pressure Rail Pressure Rail Pressure Pressure Pressure Load TIME Timing TIME (specified) (actual) Difference TIME Marker STAMP /min % ms g/s STAMP bar bar bar STAMP bar bar % 0.14 1560 14.3 0.51 4.94 0.27 50 49.98 0.02 0.01 4 3.88 37.6 0.52 1680 60.9 2.55 32.81 0.66 72.95 74.84 -1.89 0.39 4 3.94 39.6 0.91 1640 75.2 2.81 28.94 1.03 95.77 98.25 -2.48 0.78 4 3.88 47.1 1.3 1720 82 3.06 32.69 1.43 103.54 106.92 -3.38 1.18 4 4.19 46.7 1.69 1800 89.5 3.31 37.39 1.82 105.85 108.29 -2.44 1.55 4 4.39 45.1 2.07 1880 95.5 3.57 41.22 2.21 107.83 108.88 -1.05 1.94 4 4.41 44.7 2.45 2000 102.3 3.57 46.47 2.58 109.83 110.41 -0.59 2.33 4 4.37 44.3 2.85 2120 109.8 3.83 52.67 2.97 113.79 113.83 -0.05 2.72 4 4.29 44.3 3.24 2240 118 4.08 61.11 3.36 118.32 118.87 -0.55 3.1 4 4.19 45.5 3.61 2360 128.6 4.34 71.42 3.75 123.77 123.74 0.02 3.48 4 4.12 46.3 4 2480 142.9 4.84 83.06 4.13 128.49 125.96 2.53 3.88 4 4.05 48.2 4.39 2640 162.4 5.87 99.81 4.52 129.81 125.98 3.83 4.27 4 4 50.6 4.78 2880 187.2 7.4 128.42 4.91 129.86 126.79 3.06 4.64 4 3.9 54.9 5.16 3000 191.7 8.42 146.31 5.3 129.86 127.04 2.82 5.03 4 3.77 62 5.55 3160 191.7 8.67 167.39 5.68 129.86 127.85 2.01 5.42 4 3.81 63.5 5.94 3360 191.7 8.42 127.17 6.07 129.86 127.33 2.53 5.82 4 3.87 63.9 6.33 3520 191.7 7.91 111.61 6.46 129.86 127.74 2.11 6.19 4 3.86 64.3 6.7 3680 191.7 7.91 192.11 6.85 129.86 128.76 1.09 6.58 4 3.83 65.1 7.09 3880 191.7 7.65 175.67 7.22 129.86 127.62 2.23 6.97 4 3.77 66.3 7.49 4040 191.7 7.65 134.33 7.61 129.86 128.26 1.6 7.36 4 3.69 67.1 7.88 4240 191.7 7.65 189.14 8 129.86 127.91 1.94 7.74 4 3.66 68.6 8.25 4400 191.7 7.91 188.5 8.39 129.86 126.63 3.22 8.12 4 3.63 70.2 8.64 4600 191.7 7.65 197.97 8.77 129.86 128.23 1.62 8.52 4 3.53 73.7 9.03 4720 191.7 7.4 200.08 9.16 129.86 129.72 0.13 8.91 4 3.55 76.1 9.43 4920 191.7 7.4 207 9.55 129.86 129.63 0.22 9.29 4 3.69 75.7 9.8 5080 191.7 7.4 210.33 9.94 129.86 129.35 0.51 9.67 4 3.77 76.5 10.19 5240 191.7 7.14 219.22 10.31 129.86 130.64 -0.78 10.07 4 3.76 78 10.58 5400 191.7 7.14 223.69 10.71 129.86 128.98 0.87 10.46 4 3.71 81.6 10.97 5560 191.7 7.14 230 11.1 129.86 129.2 0.66 10.83 4 3.76 84.3 11.34 5680 191.7 7.4 238.22 11.49 129.86 129.22 0.63 11.22 4 3.95 78 11.73 5840 191.7 7.4 245.08 11.86 129.86 129.26 0.6 11.61 4 3.74 88.6 12.13 6000 191.7 7.14 242.72 12.25 129.86 132.76 -2.91 12 4 3.83 90.2 12.52 6120 191.7 7.14 245.64 12.64 129.96 129.84 0.12 12.38 4 3.99 85.1 12.89 6240 191.7 7.14 253.75 13.04 129.99 130.85 -0.87 12.77 4 3.96 85.9 13.29 6360 191.7 7.4 251.78 13.41 129.99 130.68 -0.69 13.16 4 3.87 91.8
020				Group B:	231				Group C:	031
Cylinder 1 Ignition	Cylinder 2 Ignition	Cylinder 3 Ignition	Cylinder 4 Ignition		Pressure	Pressure	Load			Lambda Sensor	Lambda Sensor
Angle Delay	Angle Delay	Angle Delay	Angle Delay	TIME					TIME	Current Value	Specified Value
°KW	°KW	°KW	°KW	STAMP	bar	bar	%		STAMP
0	0	0	0	0.08	4.5	4.09	40.4		0.2	0.95	1
0	0	0	0	0.45	4.5	4.04	44.3		0.6	0.99	1
0	0	0	0	0.84	4.5	4.26	43.9		0.97	0.99	1
0	0	0	0	1.23	4.5	4.48	41.6		1.36	0.97	1
0	0	0	0	1.62	4.5	4.53	40.8		1.75	0.99	1
-1.5	0	0	0	2	4.5	4.47	47.1		2.14	0.87	1
-1.5	0	0	0	2.39	4.5	4.38	49.8		2.52	1	0.92
-0.8	0	0	0	2.78	4.5	4.59	49.8		2.9	0.93	0.91
0	0	0	0	3.18	4.5	4.79	49.8		3.3	0.9	0.91
0	0	0	0	3.55	4.5	4.9	49		3.69	0.89	0.91
-3	0	0	-3	3.94	4.5	4.85	49.4		4.06	0.89	0.91
-3	-3	-3	-3	4.33	4.5	4.73	50.6		4.45	0.9	0.9
-3	-3	-3	-3	4.72	4.5	4.63	52.5		4.84	0.87	0.84
-3	-3	-3	-3	5.09	4.5	4.52	57.3		5.24	0.77	0.77
-3	-3	-3	-3	5.48	4.5	4.36	62.7		5.61	0.75	0.75
-3	-3	-3	-3	5.87	4.5	4.27	67.5		6	0.77	0.74
-2.3	-3	-3	-3	6.27	4.5	4.25	68.2		6.39	0.7	0.73
-2.3	-2.3	-3	-2.3	6.64	4.5	4.16	69.4		6.78	0.71	0.73
-1.5	-2.3	-2.3	-1.5	7.03	4.46	4.2	69.8		7.16	0.73	0.73
-4.5	-1.5	-1.5	-1.5	7.42	4.46	4.22	70.6		7.55	0.73	0.73
-4.5	-1.5	-1.5	-0.8	7.81	4.46	4.18	71.8		7.94	0.72	0.73
-4.5	-1.5	-1.5	-0.8	8.18	4.46	4.14	73.7		8.33	0.74	0.74
-3.8	-0.8	-1.5	-0.8	8.58	4.46	4.1	76.9		8.7	0.73	0.74
-3.8	-0.8	-0.8	0	8.97	4.46	4.06	79.2		9.09	0.74	0.75
-3	0	-0.8	0	9.36	4.46	4.08	82.7		9.49	0.75	0.76
-3	0	0	0	9.74	4.46	4.17	84.7		9.88	0.76	0.77
-3	0	0	0	10.12	4.46	4.34	81.2		10.25	0.75	0.77
-2.3	0	0	0	10.51	4.46	4.31	85.5		10.64	0.74	0.76
-2.3	0	0	0	10.91	4.46	4.3	88.2		11.03	0.77	0.77
-1.5	0	0	0	11.28	4.46	4.38	86.7		11.42	0.77	0.77
-1.5	0	0	0	11.67	4.46	4.36	89		11.8	0.77	0.78
-0.8	0	0	0	12.06	4.46	4.34	91.8		12.19	0.77	0.78
-0.8	0	0	0	12.45	4.46	4.33	91.8		12.58	0.77	0.78
-0.8	0	0	0	12.83	4.46	4.34	91.8		12.97	0.84	0.81
0	0	0	0	13.22	4.42	5.03	56.1		13.35	0.94	0.98Have you had your timing checked?
i mean a physical check?
i will PM you later with some info mate.
Group A:	020				Group B:	026				Group C:	031
	Cylinder 1 Ignition	Cylinder 2 Ignition	Cylinder 3 Ignition	Cylinder 4 Ignition		Voltage	Voltage	Voltage	Voltage		Lambda Sensor	Lambda Sensor
TIME	Angle Delay	Angle Delay	Angle Delay	Angle Delay	TIME					TIME	Current Value	Specified Value
STAMP	°KW	°KW	°KW	°KW	STAMP	V	V	V	V	STAMP
0.01	-2.3	0	0	0	0.14	0.624	0.78	0.936	0.624	0.27	0.95	1
0.39	-1.5	0	0	0	0.52	0.78	1.092	1.092	1.092	0.66	0.98	0.92
0.78	-3	0	0	-3	0.91	1.092	1.404	1.092	0.936	1.03	0.89	0.89
1.17	-5.3	-3	0	-3	1.3	1.404	1.716	1.56	1.248	1.42	0.88	0.88
1.55	-5.3	-3	0	-5.3	1.69	1.404	2.34	2.34	1.404	1.82	0.82	0.8
1.94	-5.3	-3	-3	-5.3	2.07	1.716	2.496	2.34	1.56	2.21	0.75	0.74
2.33	-5.3	-3	-3	-5.3	2.46	1.872	2.808	2.184	1.716	2.58	0.75	0.73
2.72	-5.3	-3	-3	-5.3	2.85	2.184	2.808	2.34	1.872	2.97	0.7	0.72
3.1	-5.3	-3	-3	-5.3	3.24	2.34	3.276	2.184	2.184	3.36	0.67	0.72
3.49	-5.3	-3	-3	-5.3	3.61	2.184	3.276	2.34	2.184	3.75	0.72	0.74
3.88	0	0	0	0	4	2.964	3.744	2.808	2.808	4.12	0.78	0.77
4.26	0	0	0	0	4.39	4.212	4.368	3.432	3.276	4.52	0.78	0.77
4.64	-3	0	0	0	4.79	7.488	4.68	3.9	3.588	4.91	0.77	0.77
5.03	-3	0	0	0	5.16	8.112	5.46	4.836	5.616	5.3	0.77	0.77
5.42	-3	0	0	0	5.55	7.332	5.46	4.836	5.304	5.67	0.75	0.76
5.81	-2.3	0	0	0	5.94	7.02	6.24	5.148	5.46	6.07	0.75	0.76
6.19	-2.3	0	0	0	6.33	7.644	6.708	4.836	5.46	6.46	0.75	0.76
6.58	-2.3	0	0	0	6.7	5.46	6.864	4.836	5.148	6.85	0.75	0.76
6.97	-1.5	0	0	0	7.1	6.396	6.084	4.68	4.836	7.22	0.76	0.76
7.36	-1.5	0	0	0	7.49	6.396	6.864	5.148	5.304	7.61	0.76	0.76
7.74	-0.8	0	0	0	7.88	6.864	7.956	4.992	5.616	8	0.76	0.77
8.13	-0.8	0	0	0	8.25	7.02	8.112	5.304	5.304	8.39	0.76	0.77
8.52	-0.8	0	0	0	8.65	7.176	8.424	5.928	5.148	8.77	0.76	0.77
8.91	0	0	0	0	9.03	6.708	7.488	5.616	5.928	9.16	0.75	0.77
9.28	0	0	0	0	9.43	6.552	8.268	5.148	6.084	9.55	0.76	0.77send me a private message of your facebook details, I can put you in touch with some people who really know this engine inside out
