pioneer cd player
rocky2008
Buy Cheap Buy Twice!
Nov 16, 2008
1,029
North-east
i have a pioneer cd player in my ibiza and when i take the head unit off at night, when i go to listen to the radio the next day it has not saved the radio stations, this problem only occurs when the front of the radio leaves the main unit. anyone got any advice on what this could be?
andychef1234
62
Aberdeen
well i would say change the two cables around in the back as one will be a fork different colours? not sure about pioneer but i had the same problem with my last car head unit it was sony. swapped them round and it worked fine if you could post me a pic of the back of your head unit/wires ill tell you which ones.
it shouldnt be to difficult though
hope this helps mate
Fl@pper
Jun 19, 2001
12,370
26
Gloucester
permanent +12v & +12v ignition are probably mixed up
check for a red & yellow wire having connectors in the loom as they are usually ready to swap over
check em first though but it's usually the problem
stezo2k
Anjuna Monkey
Mar 15, 2008
2,804
Dudley
yeah its definately the the battery and the live connector being connected wrong, i had exactly the same too
should do the trick
________
Interracial Movie
veezee
Power Hungry/Clueless
Jun 10, 2008
126
London
I've had fun with my new HU last couple of days. JVC, thought I'd give it a go. Got the perma +12v wired up no worries, but for some reason it had an extra connection on the red after the ISO adapter. Looked dodgy to me, but ended up being the correct connection for the Ignition feed - yellow did sod all, finally gave up and plugged both into red.
My previous HU, a Sony, was a yellow/red swap after the ISO adapter tho.
rocky2008
Nov 16, 2008
1,029
North-east
would that be in the back of the radio? or the actuall car wires?
rocky2008
Nov 16, 2008
1,029
North-east
thanks alot for the help mate, will have to try this :)
